Over revved wtf did i hurt.....
Well i know hurt something just don't know to what extent. This is a freshly built sleeved b16 with a precision 6262 the head has springs and retainers only.. The setup has 1,050 miles on it but yesterday i was clowning around trying to scare my girl with a 3rd gear pull.. But my damn floormat got caught in the gas pedal and when i let off it, it held it wide open at 9500 rpm luckily it had a rev limiter.. I shut it off while it was wide open at 9500 probably for a good 2-3 seconds banging the rev limiter because intially i thought the throttle cable or something stuck wide open..
I figured out it was the floormat, restarted the car no symptoms at all.. I then shut it off for about 20 minutes when i got home and when i restarted it the valves were tapping pretty bad but went away after i gave it gas.. Now everytime after that i have bad valve tap on startup especially this morning when it was completely cold..
The car seems to run fine i did alil pull up to about 7k just to see how it acted but i was alil nervous about running it to 9500. I have no noticable loss of power just noisy valve..
Is it possibly the valves came out of spec and i need to get the valves adjusted?
Is it possible i slightly bent a valve?
what else can i look for?
yeah i guess i will start with a valve adjustment and compression test then go from thier.. I really don't wanna pull this head already after 1,050 miles..
haha i've done this before too.. actually a real embarassing story when i was 16.. tried pulling e-brake around a slight corner during a big snow storm and slid off and hit a fire hydrant LOL.. i have since grown up and learned from that..
TeamDOHCside
Oct 8, 2003 05:16 PM
