Integra sputtering problem!!!!need help
Old Nov 22, 2009 | 03:46 PM
mcaro's Avatar
Default Integra sputtering problem!!!!need help
Ok guys,I just bought an integra a week ago,and started to drive it the other day.drove the car about 2 hours and the car started to bog out..once you press on the gas (full throttle) it would start to spudder,but when you let off,it rides fine. I got to my house and checked the spark plugs and there was oil in there.So i dried it up really good and replaced the spark plugs and when I start the car,its idles good,i rev it and its good until i put it in drive,once i put it in drive and start to go,the car starts to bog out again,like its not getting any gas.I then turn it off and turn it back on,its fine again,idles is good and revs just fine.put it in drive again,and it does the same thing...I pulled out the fuel pump and there was bad rusty shaded gas.I empty the tank out,replaced the filters,and put fuel system cleaner and 93 octane gas in it,and its still does the same thing,when it starts to bog i can hear the fuel pump going on and off,Im going right now to change it out,but if its not this,does anybody know this problem...Thanks
Old Nov 22, 2009 | 04:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: Integra sputtering problem!!!!need help
Check the PGM-FI main Relay, it is what controls power to the fuel pump, see if it is also switching on and off, if not, I would replace the fuel pump, if it does I would check the relay, [a common problem on older Honda/Acura]... http://techauto.awardspace.com/mainrelay.html 94
slateEKsi
Jan 31, 2011 04:08 PM
LSDA9Nick
Jan 26, 2008 11:13 PM
DA6_toojy
Oct 12, 2005 06:30 PM
Cabby89
Oct 17, 2004 08:34 PM
93egsi
11
Jun 18, 2004 05:37 AM
