Transmission & Drivetrain Gearboxes, Differentials, Clutches
new clutch burning?
Old Nov 22, 2009 | 09:57 AM
j.packsb's Avatar
Default new clutch burning?
i jus recently put in a comptetition stage 3 six puck clutch that was very lightly used in my d16y8. an now after 2 days, its making a burning smell. it grabs find and does not slip at all. performs way better than the oem one i took out. anyone have any ideas why its making this burning smell? any help would be greatly appreciated.
Old Nov 23, 2009 | 05:18 AM
j.packsb's Avatar
Default Re: new clutch burning?
bump. no help?
Old Nov 23, 2009 | 01:11 PM
vietherbs's Avatar
it helps to know what kinda of smell it is.
did you change your rear main seal upon clutch install?
do you have a vtec solenoid leak or v/c leak?
Old Nov 24, 2009 | 05:14 AM
j.packsb's Avatar
it smells like burnt clutch. very close to burnt rubber/tires. no i did not replace the main seal..? didnt know i needed to.
Old Nov 26, 2009 | 02:32 PM
stevenDAtegra's Avatar
New clutches sometimes give out the burning smell. My friend broke his in and then did a pull and it was a really strong smell but then never did it again. Did you adjust the pedal?
Old Dec 2, 2009 | 06:04 AM
almogmap73's Avatar
You can just get a new disc, but it will still slip on high boost.
Clutch does the biting, not the pressure plate. Pressure plate just clamps the clutch against the flywheel.
harrykong
Aug 26, 2006 07:14 AM
DB1_559
Jun 23, 2006 03:02 PM
NOSED_CRX_VTEC
Oct 7, 2004 11:20 AM
type autox
Dec 11, 2001 07:07 PM
