QUICK!!! Wire color for Knock and RPM in OBD2A EK SOHC Vtec harness
I have the ecu apart, and all wires exposed...need to get this done tonight.
This is what I'm installing....
A Turbo XS Knocklight/Shiftlight
THANKS....ON MY WAY TO AUTOZONE NOW TO GET REST OF EQUIP. NEEDED!!!!
Ok I just looked in my 96-00 civic Helms manual. And the colors are:
knock- Red-Blue ( at the ecu and at sensor)
For the rpm, your gonna have to go to the distributor (blue wire) or theres a rpm test connector at the drivers side firewall (corner). When you look in that corner (clutch fluid res area) you'll find a grey connector (not connected to anything) with a single blue wire going to it. You can tap into that for the rpm signal.
I'm looking on my helms book and the 99-00 ecu diagram shows a wire that has the rpm signal going to the ecu. But I checked every single wire on the 96-98 harness and none of them are labled rpm signal.
thanks hondadriver..... I got everything wired up and working except for rpm signal....are you positive theirs no rpm signal going into the cu...how about VSS signal....can I use that? Only reason I ask is cause i routed the rpm signal wire through the guage cluster, back behind the dash, and back out the rear of the glove box. Basically its gonna be a headache to get that wire back out and rerouted into the engine bay nearest the drivers side....
Its my own fault though for rushing things
I just read the haynes....yea I gotta tap that blue wire.....I'll tap it within the dash right before the cluster....to save me the trouble of routing the wire through the firewall. thanks
tekstyle
Feb 27, 2008 12:15 PM
