crank pulley interchangeable? Help!
Hi all,
Are B series crank pulleys interchangeable? I have a B18c in a DB2 but cant get power steering to work because the B17 power steering pump uses a "V" shaped belt but the crank pulley on the B18c is "ribbed" style. I tried to use the B18c PS pump but the line from the DB2 rack will not bolt to the B18c PS pump.
Im thinking of getting an old LS crank pulley with "V" shape PS belt and putting it on the B18c but am wondering if this will negatively effect the B18c harmonics or bearings or oil pump or anything. Please let me know. If anyone has any other suggestions that would be appreciated as well.
FYI swapping the pulleys on the pumps will not work either because size of bolt that holds them on is different.
I tried searching but all I found were "How do I remove crank pulley" threads.
