Places to buy wiring harnesses?
Old Sep 1, 2002 | 08:36 AM
!canadian!'s Avatar
Default Places to buy wiring harnesses?
I am getting ready to swap a 1.5L SOHC 102HP out of my 93 Del Sol and replace it with a 1.6L JDM Spec SiR-2 DOHC 170HP, but the harness is cut off because of the LH/RH issue. I want to purchase a custom harness for the swap.....can anyone help?
Old Sep 1, 2002 | 09:03 AM
BigBlockCRX's Avatar
New User
Default Re: Places to buy wiring harnesses? (!canadian!)
just use your old 1.5 harness. dont cut any wires off of it.. and it you should be ok
just stick both motors on the ground side by side, you may have to lengthen some wires, like TPS and MAP (maybe) but they should all plug right in, you might have to add like 4 wires, they would be: Knock Sensor, Vtec Oil pressure (2 wires), and vtec solenoid (1 wire). adding four wires is a lot cheaper and faster than spending 250 bucks for a harness you dont really need
good luck
Old Sep 1, 2002 | 09:12 AM
!canadian!'s Avatar
Default Re: Places to buy wiring harnesses? (BigBlockCRX)
thanks for your suggestions, do you know where i could get a wiring diagram, my helms manual got lost in the mail about two weeks ago now.
Old Sep 1, 2002 | 02:19 PM
New User
well, I dont have a scanner..
You really dont need one. like I said, just take both motors, or better yet, when you pullyour 1.5 out, take some masking tape, and write on each plug where it goes.. example: TPS, MAP, IACV, injectors, etc.. the dohc motor is just like the sohc motor, except for vtec, and the knock sensor, everything else is exaclty the same, only the length of the wiring is different.
its really simple.
the knock sensor is on the back of the block betweeen #1 and #2 pistons, small sensor, you need a 27mm deep socket to take it off and it has only 1 wire coming out of it. (its an actual plug, not just a simple push on wire)
the vtec solenoid is also 1 wire, and its grn/yel. the vtec pressure is right next to the solenoid and has two wires from it, one you ground to the block and the other you send to the ecu, just 4 simple wires that some shops charge hundreds of dollars for..
as for sites, you might try this one..
http://www.hybridforums.com
and do a search there
Old Sep 1, 2002 | 04:15 PM
keebler65's Avatar
and dont forget about the 2nd O2 sensor. thats one wire also, on the exhaust manifold
Old Sep 2, 2002 | 09:40 AM
ndogg's Avatar
Default Re: Places to buy wiring harnesses? (keebler65)
there is no second o2 on obd1. also, JDM engines don't have vtec oil pressure sensors so when you can't find that, don't worry, it ain't there. as long as you are using a JDM ECU, you'll be cool. if you don't have a JDM ECU for some reason, you can probably get a chip or just trade someone for one.
untitledsn41
Jul 27, 2004 07:16 PM
labatia
Jun 24, 2004 05:27 PM
turkdog
Jun 12, 2003 02:20 PM
rasta420
Audio / Security / Video
May 6, 2002 06:58 AM
