jdm h22a idle problem
Old Nov 20, 2009 | 01:47 PM
2jdm4uh22ek's Avatar
Default jdm h22a idle problem
Here's the problem - i have a jdm h22a in my ek with just bolt on's like hytech header & type s cams & euro r intake man. - jg edelbrock throttle body and Ive been playing around with my throttlebody now for a few days because it seems like i cant get the idleset screw just right - the more you open or tighten the screw it causes the idle to increase and its like there's a vacuum leak - (Idles up and down) - right now i've got it perfect but it idles at around 900-1000 RPM. Is this where it should be??????
Old Nov 20, 2009 | 02:38 PM
delsolproblems's Avatar
Default Re: jdm h22a idle problem
Check the TPS voltage.
Old Nov 21, 2009 | 06:53 AM
k ill thanks ill try it today
Old Nov 21, 2009 | 08:26 AM
TheRappist's Avatar
IACV. My JDM H22 does the same thing; IACV is dirty. It needs to be cleaned, and if that does not work, it needs to be replaced.
mikelesnick
Aug 7, 2018 02:05 PM
Sir_LagaLot
Jul 30, 2016 11:19 AM
94@ccordlx
17
Oct 10, 2010 07:32 PM
duceducecord
Dec 21, 2006 08:35 PM
GOTNOS
Nov 28, 2004 04:05 PM
