Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
brake fluid
Old Nov 20, 2009 | 09:53 AM
chiggin's Avatar
Default brake fluid
I am planning on changing my brake fluid tomorrow. I would like to upgrade to a high temp fluid that will not boil on track. Anyone have a suggestion on what fluid to use?
I was thinking about using ATE Superblue. I have been told that it should work unless Honda used DOT 5 from the factory. Anyone know what the Honda factory brake fluid is? Has anyone used Superblue in their Si?
Old Nov 20, 2009 | 10:13 AM
pd0019's Avatar
Default Re: brake fluid
didnt use ATE Blue on an SI, i had an EX and it worked fine. no track use so dont know about that, but you can read up on it on 8th
Old Nov 20, 2009 | 11:29 AM
av911's Avatar
Honda uses DOT 3:
http://www.handa-accessories.com/civmaint06.html
Old Nov 22, 2009 | 06:57 AM
=honda4life='s Avatar
On my brake fluid cap it says use only DOT 3/DOT 4. Dunno if that helps lol
Guimba
Suspension & Brakes
Feb 17, 2010 06:05 PM
blipmode188
Mar 7, 2009 01:56 PM
Elvis1977
Jul 24, 2007 11:49 PM
CivicSiRacer
24
May 15, 2003 12:03 PM
Thrillhouse
Oct 19, 2002 08:42 PM
