94 LS won't start
Old Nov 19, 2009 | 11:35 PM
kgreenhaw's Avatar
Default 94 LS won't start
I parked my Integra and came back the next day to find that it would not start. First I had problems with the starter, I would just hear a click, so I began addressing that issue. I ran a few tests, everything checked out. The battery cables were a bit loose, I cleaned the connections, tightened them. I tapped on the starter and then tried to start the car. The engine turned over but wouldn't fire. Tried a few more times, then the starter was only working intermittently and still won't fire. I have fuel and spark. What could it be? any ideas?
Old Nov 20, 2009 | 08:38 AM
boost562's Avatar
Default Re: 94 LS won't start
If your car is sticks shift try push starting it. if it starts try a different battery first and then a starter but make sure all your cables are good and not all corroded. You could have spark and fuel but if you don't have enough power it wont turn on.
Old Nov 21, 2009 | 05:03 PM
kgreenhaw's Avatar
I ended up checking the spark plugs, replaced them, put in a battery and it fired up! thanks!
95delsolz6
Dec 10, 2009 03:33 PM
EjSex
Aug 17, 2007 08:20 PM
2camsaam
Jun 27, 2007 01:10 AM
alfee
Apr 4, 2005 07:03 PM
andrew n
May 25, 2004 10:46 PM
