What injectors to use with 92 b18a1 ?
Old Sep 1, 2002 | 07:00 AM
FUP23's Avatar
New User
Default What injectors to use with 92 b18a1 ?
I just heard someone say use stock Si injectors ?? Im still running the 92 b18a1 injectors ...Whats the right thing to do
Old Sep 1, 2002 | 07:02 AM
CRXBart's Avatar
Default Re: What injectors to use with 92 b18a1 ? (Devin17)
440cc DSM injectors cheap and really big, you'll need a VAFC to control it though.
Old Sep 1, 2002 | 07:03 AM
FUP23's Avatar
New User
Default Re: What injectors to use with 92 b18a1 ? (CRXBart)
yeah those are quite huge ...I dont think im wanting anything that big n/a right now
Old Sep 1, 2002 | 08:20 AM
flat-blk-HB's Avatar
Did you convert your car to OBD1? Becasue as far as I know you cant use 92+ injectors unless you do the conversion to OBD1. I have a 92 B18A1 and I am using all 91 OBD0 stuff...Injectors,Dizzy,ECU..You can use the 88-91 SI injectors too, you will have to use the Resistor box, which I am using with my obd0 injectors.
Old Sep 1, 2002 | 08:36 AM
FUP23's Avatar
New User
Default Re: What injectors to use with 92 b18a1 ? (ED6)
Well ... Nope Im running obd0 with a pr4 using the b18a1 92 injectors and using a resistor box .....Is this ok ?
Old Sep 1, 2002 | 10:05 AM
As far as I know that set-up will not run correctly. Because the style of injector, the 92+ are not the same style as 91 and down. The 92+ tegs dont use resistor boxes. There are names for these 2 styles injectors not sure which is what but somebody knows. Are you sure the injectors are 92? IS it running good?
Old Sep 1, 2002 | 10:17 AM
FUP23's Avatar
New User
Yep Im sure ..its runs very very strong
Old Sep 1, 2002 | 10:24 AM
DUCK COMMANDER's Avatar
integras didn't go OBD1 till 94
(i think peak and hold injectors are on OBD0 and saturated are on OBD1-2)
[Modified by JSutterEH2, 2:25 PM 9/1/2002]
Old Sep 1, 2002 | 10:34 AM
Default Re: What injectors to use with 92 b18a1 ? (JSutterEH2)
nope tegs go 0bd1 from 92-95 I know this for a Fact
Old Sep 1, 2002 | 11:31 AM
hybridhatch90's Avatar
chances are that you have 91 injectors. the plugs are different on the obd1 injectors. will not plug into the si harness. which harness did you use?
on a side note, or thread jacking as it may be, how much are those 440cc dsm injectors and does anyone have some? will they plug into the si harness or do the clips need to be changed?
Old Nov 5, 2009 | 06:20 AM
93ivtecDa9's Avatar
you can use h22 injectors thats what im doing
Old Nov 5, 2009 | 06:53 AM
gibsanez's Avatar
THIS THREAD IS ALMOST 8 YEARS OLD
Old Nov 5, 2009 | 07:07 AM
88Hatchy's Avatar
Originally Posted by gibsanez
THIS THREAD IS 7 YEARS OLD
fixed
G3RaCeRz
Jul 6, 2019 06:03 PM
civicefdx
Oct 18, 2004 04:38 PM
Anthonyl469
Jul 25, 2004 08:16 AM
TooDrunk2See
Oct 26, 2003 11:31 PM
T60-1VTECrex
Mar 3, 2003 04:52 PM
