Transmission & Drivetrain Gearboxes, Differentials, Clutches
aim me clutch problems b16
Old Nov 19, 2009 | 02:20 PM
HaveUseenMy_Tq?'s Avatar
Default aim me clutch problems b16
i got a problem with my clutch and its weird... i have basic knowledge of manuel trans, and im confident i can replace the clutch on my own... buttt before i go buying anything heres my perdiciment..
1.clutch pedal feels PERFECT
2.when in gear and clutch pedal is depressed at complete stop, i am catching chatter/ grab and let go sh*t
3.gears are difficult to engage
4.Master cylinder clean as a whistle all around outside
5.Cotton Picking cylinder clean as a whistle as well, even behind the boot and everything.
it is a stock clutch that has 80% highway miles on it and was adult driven untill about 5k miles ago..
it has 118k on the clock
even up hills in first gear from a slow roll if i mash it , its not slipping, i am getting chatter when trying to normally engage the clutch taking off in first gear...
if anyone can help please aim me ill be on for a good minute waiting for help..
turd99si
Old Nov 19, 2009 | 03:39 PM
Default Re: aim me clutch problems b16
signed off aim drop a message thanks
Old Nov 20, 2009 | 07:24 PM
David12's Avatar
i have the exact same problem except for my clutch isn't stock. changing my clutch and bearings this weekend. I'm pretty confident it'll fix the problem.
Old Nov 20, 2009 | 10:18 PM
Turbo B18C EJ6's Avatar
sounds, like maybe a spring broke in your clutch disk. have to pull the trans to find out.
Old Nov 21, 2009 | 11:35 PM
Mista Bone's Avatar
D Tranny Guru
I concur, typically happens at about 60-70k miles on a OEM B clutch, but with the highway miles.......it's time @ 118k!
Old Nov 22, 2009 | 08:31 AM
David12's Avatar
replaced my clutch and flywheel and it fixed the problem.
Old Nov 23, 2009 | 04:19 AM
straight thanks , i figured it was the spring, same thing happened to my 180sx ... guess ill be replacing it this weekend. yay.
old_school_dohcvtec
Oct 4, 2007 09:47 AM
2wheelhunter
Aug 30, 2006 07:32 PM
scrubachu
Jul 11, 2005 08:49 AM
ls95hatch
May 24, 2003 09:34 PM
jdmteg95
Dec 17, 2002 03:52 AM
