Would a crooked rim in the back cause my car to jerk left and right
Old Nov 19, 2009 | 02:20 PM
Hanmin's Avatar
Default Would a crooked rim in the back cause my car to jerk left and right
I just painted some vx's, and it turns out one of them were crooked. I put it in the back and about 2 weeks later my car is jerking crazily. any answers to why? I've also got an allignment after I lowered it and put the vx's on. This is on a 95 civic cx with rear integra discs.
Old Nov 19, 2009 | 02:42 PM
David12's Avatar
Default Re: Would a crooked rim in the back cause my car to jerk left and right
did you have the crooked wheel balanced?
Old Nov 19, 2009 | 02:53 PM
shawn_crx's Avatar
just image that you walk like your rims..
Or talk... lol
Old Nov 19, 2009 | 03:07 PM
Koopa Troopa's Avatar
A bad alignment will make your car "jerk", a bent wheel will not.
Old Nov 19, 2009 | 04:42 PM
Hanmin's Avatar
My car jerks to the right alot. Sometimes softly, sometimes very aggressively, to the point that it slips out of my hand.
What would have to be wrong with it? for it to jerk. I'll upload a video of some of the jerking.
Old Nov 19, 2009 | 04:59 PM
93egSLEEPER's Avatar
please no vidoes of you jerking in your car......
couldnt resist
If the wheel is bent enough and causes the it to spin out of round (straight up and down) it will creat a side to side motion. the car will follow the path of the wheel/tire.
Old Nov 19, 2009 | 05:17 PM
Hanmin's Avatar
http://www.youtube.com/watch?v=vewV-eVQVZ8
just watch the first few seconds...
Old Nov 19, 2009 | 05:19 PM
shawn_crx's Avatar
your a je*k... your a je*k dance is on youtube
Old Nov 19, 2009 | 05:44 PM
Hanmin's Avatar
Heres the whole story. Went home one weekend, painted my wheels, got new tires for the fronts, and made sure the crooked tire went in the back. I lowered my car with the tires on and got an alignment at firestone/bridgestone whatever its called. Then it was good for about 2 weeks, then just as I was driving somewhere today, it started jerking slightly, then an hour later it started to get aggressive. I want to go home tomorrow, hoping to fix it in the morning.
Old Nov 19, 2009 | 05:50 PM
eg2jr's Avatar
check for a loose LCA bolt etc that can cause to make the car jerk since they might have some play and move side to side.
Old Nov 19, 2009 | 05:52 PM
96CiviCoupe's Avatar
i got the same thing, just not as bad as your video showed. i've been thinking that it maybe cause my wheels aren't balanced. not too sure tho.
Old Nov 19, 2009 | 06:03 PM
backyard_concepts's Avatar
change your wheels back to the others, that will tell you if the wheels are the problem
Old Nov 19, 2009 | 07:34 PM
You answered your own question. If the alignment was fine for 2 weeks then it IS NOT THE BENT WHEEL. Obviously something loosened up due to not being tightened correctly and your alginment is now off.
Unbalanced wheels will cause vibration, not make your car 'jerk' every where.
It'll cause vibration but the wheel will follow the alignment. I've limped cars home with flat tires, destroyed wheels, etc. The only time they've not driven straight was if something was bent.
Old Nov 19, 2009 | 07:56 PM
ImportHatch's Avatar
Sounds like the front tires are toed in. Get an alignment.
Old Nov 20, 2009 | 01:00 AM
Hanmin's Avatar
Alright, I'll try for another alignment in the morning.
I was brainstorming when I first made this post, that was just a brainstorm for my problem.
Old Nov 20, 2009 | 01:08 AM
es01civy's Avatar
bad tie rods???
Old Nov 22, 2009 | 01:10 PM
Hanmin's Avatar
http://www.acura-legend.com/vbulleti...lently-133496/
its an axle problem, same exact thing, was just snowing not too long ago. just for future reference
hcaulfield57
Suspension & Brakes
16
Aug 27, 2017 03:09 PM
tianporn
Suspension & Brakes
Oct 2, 2013 11:07 AM
spectastic
Honda Civic (2001 - 2005)
10
Sep 6, 2013 02:01 PM
r3000
Dec 20, 2004 09:29 AM
lilman36
Nov 24, 2003 07:49 AM
