d16z6 running rich
Old Nov 19, 2009 | 01:10 PM
lalocivic's Avatar
Default d16z6 running rich
black smoke comes out at low idle like bogging car runs bad when warm but when cold run fine oil smells like gas sparkplugs are black i only have bolt ons what can it be checked injectors did a tune up and still the same is running rich bad for ur motor and the smell of gas is strong one more thing does gas in your oil mess up the motor??
Old Nov 19, 2009 | 01:13 PM
Matt93eg's Avatar
Default Re: d16z6 running rich
How long have you had this car? Is the ECU Chipped?
I would consider gas in your oil a bad thing. Seems to be the fuel would thin the oil out and cause the oil not be as slick as normal. However, I am no expert on that.
Old Nov 19, 2009 | 01:18 PM
Former User's Avatar
Incorporate some punctuation into your writing.
Any CEL codes? Is the ignition timing set to spec? Is your fuel pressure high?
Old Nov 19, 2009 | 10:08 PM
96honda_EK's Avatar
Oh dude i had this problem with exactly the same motor. It was my tp sensor. Its the sensor on top of your intake manifold. I was missing a little rubber part that holds the sensor to the manifold. I got that lil rubber thing and it was fine. But yeah it was running hella rich. Like gas was literally squirting out of the exhaust. So yeah you might wanna check that out
pedrolucas
Mar 7, 2010 12:46 PM
esean93
Nov 28, 2008 09:06 AM
Juan_Mitosis
17
Jul 16, 2008 02:41 PM
Blazin Si
19
Jun 26, 2005 08:59 AM
Layziebtnh055
Apr 13, 2004 06:26 PM
