HELP oil leak behind block
Old Nov 19, 2009 | 10:26 AM
bee20_vtec's Avatar
Default HELP oil leak behind block
99 accord auto
4 cyl
i have a oil leak behind the block, its leaking somewhere between the oil sensor n oil pan. somebody told me that there's a seal (ring) thats inside where u screw the oil filter on sometime goes bad. ANYBODy had a leak like this before please help, its getting cold i wanna get this fix before it SNOW... thanx
Old Nov 19, 2009 | 10:33 AM
accord2nrz's Avatar
Default Re: HELP oil leak behind block
This is going to sound rudimentary but drive your car up onto a set of ramps. Wipe the area clean with a rag, then start er up and look to see for sure. other option is to spring baking soda or power around the area and fire it up fora minute or two and then kill it and crawl under there and see where the leak is then you'll know how to start approaching the repair.
Old Nov 19, 2009 | 12:14 PM
craiger28's Avatar
It is either the oil sensor o-ring or the oil filter itself. Yes the filter has a rubber seal on it and have been known to leak. If you do an oil change that might fix the problem. Are you sure that the oil filter is on the engine tight?
Old Nov 19, 2009 | 05:00 PM
fleetw00d's Avatar
Not sure on the 99, but 93 EX had an oil cooler on the back of the block to which the oil filter mounted. I had to replace that seal once to fix a leak. As everyone else said, best thing to do first is clean the back of the block (power wash, engine cleaner and hose, degreaser and rag, whatever), then run it a while or drive it a bit, get under it and trace the leak. If you don't have a manual for it, Majestic Honda's exploded views on their parts site can help you identify what other seals might be in the area.
JustCant5topMe
Aug 16, 2013 12:18 PM
patrick4588
Dec 12, 2007 09:37 AM
climb_on
Sep 30, 2007 06:48 PM
92accordEX4life
Jan 17, 2006 05:30 PM
People_Mover
May 19, 2003 01:05 PM
