b18b1 pistons/rods
Old Nov 18, 2009 | 10:19 PM
jeffayre's Avatar
Post b18b1 pistons/rods
Looking to put low compression pistons and rods in my 95 b18b1 ls. Does anyone have suggestions on any types? 9:1? What is the stock bore size 81.5mm?
Old Nov 19, 2009 | 12:41 PM
ek-g6's Avatar
Default Re: b18b1 pistons/rods
Stock bore size is 81mm. i think 9:1 is good if you going turbo.
Old Nov 19, 2009 | 02:58 PM
ILS_09's Avatar
What's wrong with the stock ls piston and rods lol?
Old Nov 20, 2009 | 02:11 PM
jeffayre's Avatar
Because i put that motor in for 3 days with my small td04 turbo pushing 7 pounds of boost and it already blew a piston some how. So i think it was already cracked when i first bought the motor and it didnt show in the compression test
Old Nov 20, 2009 | 08:58 PM
ILS_09's Avatar
Damm that's odd. I see people push 16psi on a t3/t4 with stock head and block.
Old Nov 21, 2009 | 07:31 AM
Schister66's Avatar
Man U FTW
I'm sure the problem was tuning related and not based on the internal components. I made 315whp/216wtq on my stock GSR with no issues. Building it isn't going to fix the problem UNLESS you actually address the problem causing these issues. With such a tiny turbo making almost no additional power, i dont know how you busted up the internals.
**By the way, PSI doesn't mean anything...so saying "16psi on ...." doesn't give us any real measure of anything. There are such vast differences between the "T3/T4" variants.
Old Nov 21, 2009 | 10:52 AM
c95gsr's Avatar
Stay all motor fTW
Old Nov 21, 2009 | 11:40 AM
ILS_09's Avatar
Yeah that's what I'm guessing. I figure it was tuning related also.
hilson478
Oct 7, 2015 10:32 AM
the.hamburglar
Sep 29, 2005 05:59 AM
hotimportcrx
Aug 27, 2005 11:12 AM
tegon-gsr
Dec 4, 2004 09:12 AM
