Protection after welding question
Old Nov 18, 2009 | 07:39 PM
ungcobob's Avatar
Default Protection after welding question
Hi,
I welded some seat belt mounts into my crx and was wondering is having surface rust okay or should I spray paint wherever the welding was done, if possible. In general should spray paint be applied anywhere welding was done.
Thank you for you time
Old Nov 19, 2009 | 07:18 AM
miguel329's Avatar
Default Re: Protection after welding question
did you clean the spot before you welded?
Old Nov 19, 2009 | 10:10 AM
ungcobob's Avatar
Yeah i paint strip the area before welding, My welder isn't good enough to go through paint. But after welding on the back side of the welding spot, I know the paint behind it is burnt off. Not too sure if that's really a problem if its not going to go through a lot weather elements
Old Nov 19, 2009 | 08:46 PM
Jenkinsal2's Avatar
I would clean it up and paint it once you got rid of the rust on both sides.
Old Nov 21, 2009 | 02:06 AM
ungcobob's Avatar
Lets say there is no easy access to the other side, what should be done like for example in this picture of my welded in seat mount
Old Nov 23, 2009 | 09:14 AM
JDM1civic's Avatar
you could spray the back of the pieces with a weldable primer before you started the job, also i would be a little concerned with the strength/durability of that seat mount, if that car was in a side collision, i could picture that mount being instantly torn off. not criticizing, just trying to look out from a saftey standpoint.
Old Nov 23, 2009 | 08:03 PM
ungcobob's Avatar
O safety is most definitely, I've done a couple of hours practice welding on sheet metal and random brackets, then cut them apart to see if it penetrated and took a couple of sledge hammer wacks to see if they break. Im not pretty sure if that proves anythin lol. Advice are welcome!!
Thanks for the feed back
s13hero
Nov 17, 2011 01:00 PM
GoLowDrew
Paint and Body
May 16, 2010 05:21 AM
boostedb20z
May 10, 2009 02:20 PM
Acidcrakker
Paint and Body
11
Dec 2, 2008 01:38 AM
Brian-Brian
May 18, 2003 09:06 PM
