Suspension & Brakes Theory, alignment, spring rates....
which suspension bushing will lead to wheel hop?
Old Nov 18, 2009 | 06:21 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default which suspension bushing will lead to wheel hop?
just got a full energy suspension master bushing kit, but I was wondering which bushings will most likely cause wheel hop? Iv solid mounts, one piece coilovers and a lsd and am still having issues.
not interested in getting traction bars yet.
Old Nov 18, 2009 | 07:05 PM
redboost10's Avatar
Default Re: which suspension bushing will lead to wheel hop?
are you on slicks and what power? i replaced just about every single bushing in my front end with polyurethane ones except for the lower control arm ones where the a-arms bolt up to (which i dont think they make but could be wrong) and i have no wheel hop issues. i never had wheel hop issues to start with
have you bought a kit?
Old Nov 18, 2009 | 07:11 PM
phunhaus's Avatar
The complete answer is: all of them.
The deflection is from the wheel moving back and forth inside the wheel opening. Since the wheel is attached to the knuckle and the knuckle is attached to both the upper and lower control arms all of the bushings play a part in eliminating this deflection.
Old Nov 19, 2009 | 12:52 AM
Loved
Community Favorite
ok, and 200+whp na , street tires.
Old Nov 19, 2009 | 05:51 AM
kommon_sense's Avatar
Ever had your car corner weighted? You can eliminate wheelhop in a 200whp n/a car WITHOUT traction bars...
For me cornerweighting got rid of most of my wheelhop, and getting better tires got rid of the rest (went from azenis rt615 to dunlop star specs for street use).
Also what tires are you running?
Old Nov 19, 2009 | 08:00 AM
Loved
Community Favorite
I believe my tires are a big culprit, I have some old dunlop sp8000 in a 215 45 15, I will be getting a set of kumho xs's some what soon, trying to get all the wear out of my tires so my new ones will last longer.
Old Nov 19, 2009 | 04:03 PM
Loved
Community Favorite
found out that 90% of my wheel hop was due to ****@ss tires.
Old Nov 20, 2009 | 07:30 AM
CRX T-Si's Avatar
No mention of the compliance bushings and I know the ES kit does not come with it. I personally do not like the ES kits but consider changing out the compliance bushing with one from Hardrace it would help with wheel hop.
Old Nov 20, 2009 | 09:37 AM
Loved
Community Favorite
it does come with the compliance bushing, well at least my kit did. thats what I plan on replacing first.
DAsix
Aug 23, 2004 05:31 PM
TurboDANDEE
Mar 22, 2003 09:04 PM
tnord
Mar 9, 2003 03:21 PM
KoRE
Oct 17, 2002 08:24 AM
ALF
May 18, 2002 09:29 AM
