timing belt... how hard?
i have a 1999 accord ex 2 door with 2.3 F23a1 i bought this car for 2k and all i did was installed a new radiator. the car has 215k on it and still runs like a top but i want to chang eboth the cam timing belt and the balance shaft belt as well as water pump cam and crank seals. i turn wrenchs for a living but i have never done a timing belt before.
slightly different engine but mostly the same procedure...
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
If you turn wrenches then I would say that this would be an easy task for you. Air tool impact will take off the crank shafy bolt. Make sure you set the engine on top dead center before you go pulling off the belts. Cam shaft marks on back of camshaft sprocket/pulley. White line on Crank shaft pulley. Hole in the bellhousing of tranny. Good luck.
wk9k
Mar 13, 2012 05:45 PM
Randysi
12
Oct 20, 2011 03:00 AM
sukcak
Jul 17, 2008 07:45 AM
