k20a2 or k20z1
Old Nov 18, 2009 | 05:29 PM
jjbassham79's Avatar
New User
Default k20a2 or k20z1
I dont know if this is the right section or not im new to the sight but im about to buy a complete k20z1 swap and was wondering the differences if any in swapping it or a k20a2 in my 97 coupe its a complete swap from axles to fuel lines and all which are all from hybrid racing i believe any info would be helpful before i purchase! Thanks Guys!
Old Nov 18, 2009 | 08:00 PM
judgeDredd's Avatar
Default Re: k20a2 or k20z1
the z1 has more of the same parts that the type r version has that why it make 10 more hp then the a2, well at least thats what wiki says lol
2005 & 2006 RSX Type-S Additional Enhancements:
* The engine intake and exhaust modifications that boost the power of the Type-S models to 210 hp (157 kW) at 7800 rpm (revised to 201 hp (150 kW) in 2006), compared to 200 hp (150 kW) at 7400 rpm on the previous model.
* Higher performance camshafts sourced from the Type-R engine
* An enlarged throttle body sourced from the Type-R engine
* Air intake duct enlarged for increased air flow
* Larger diameter exhaust pipes to increase exhaust flow obtained from the Type-R model
* Catalytic converter optimized to reduce exhaust backpressure
* Larger diameter front strut tower bar gas
* Bushings replaced by bearings on strut mount
* Deck lid spoiler
* 6-speed transmission optimized with a lower final gear ratio for quicker acceleration and carbon synchronizers replacing brass on 5th and 6th gears for a smoother shift feel
Gear Ratios for the 2005 & 2006 revision
Gear Ratios 1st Gear - 3.267 2nd Gear - 2.130 3rd Gear - 1.517 4th Gear - 1.147 5th Gear - 0.921 6th Gear - 0.738 Reverse - 3.583 Final Drive - 4.765
Old Nov 22, 2009 | 06:56 PM
HseriesWeaksauce's Avatar
No the camshafts are no the type r cams. The 210 has nothing to do with exhaust it is from the slightly more aggressive cams. The throttle body is not the same as the type r either thus why you need the spacer to use the RBC. Also the Z1 was the NSN4 Trans with a 4.7 final as in a higher final than the 4.4 final, where do you get you information from?
Old Nov 22, 2009 | 09:00 PM
New User
Either way thanks guys i kinda figured it all out now was just looking for a little insight got my engine and collecting parts super pumped and cant wait to drop it in!
Old Nov 23, 2009 | 05:20 AM
judgeDredd's Avatar
Old Nov 23, 2009 | 10:11 AM
New User
Its all good i seen the same as well im happy with what i got 1300 for almost complete swap and another 800 for new axles fuel regulator wiring harness and mounts all from hybrid racing all on craigslist gotta love it!!!
John Piche
30
May 24, 2013 12:33 PM
EG1834
13
Jan 19, 2011 03:46 AM
604_yamamoto
Oct 9, 2008 05:04 AM
bandito2002SE
Oct 18, 2007 03:57 PM
biff
14
Apr 14, 2004 06:16 PM
