B18B1 LS Integra Spedometer Fluttering Issue
Old Nov 18, 2009 | 03:17 PM
senser1080's Avatar
Default B18B1 LS Integra Spedometer Fluttering Issue
Hey guys I was driving today and I noticed under hard acceleration, my speedometer flutters from around 60 to 70 mph up and down then stabilizes after I let off the accelerator.
Any ideas on what could be causing this problem. It only happens when I punch it hard and at high RPM
Old Nov 18, 2009 | 04:43 PM
senser1080's Avatar
Default Re: B18B1 LS Integra Spedometer Fluttering Issue
Nein?
Old Nov 18, 2009 | 05:12 PM
TwotoneC1Da9's Avatar
check the wiring from the vehicle speed sensor on the tranny, make sure its tidy, ive seen this before
Old Nov 18, 2009 | 06:08 PM
stu8319's Avatar
New User
The actual speed sensor maybe loose as well, but you'd probably see that needle fluttering at all speeds.
Old Nov 18, 2009 | 06:51 PM
teamjdm239's Avatar
agreed. something with the speed sensor connections.
Old Jan 2, 2010 | 07:26 PM
senser1080's Avatar
Thanks guys even if I'm reviving a 2 month old thread. I got a CEL #17 and the speedo didn't work for a little bit then it came on. So I'm sure that the problem is from the speed sensor wiring.
doubleoazn03
Sep 5, 2008 10:33 PM
bg-33p
Feb 12, 2005 10:33 PM
SPOON_FED_DC_2
Jul 29, 2004 01:13 AM
GSRxDxGSR
May 5, 2004 02:19 PM
Mike95lude
Feb 18, 2002 09:50 PM
