no interior lights work on DA- bad icu?
Old Nov 18, 2009 | 01:06 PM
TwotoneC1Da9's Avatar
Default no interior lights work on DA- bad icu?
My interior lights, rear defroster, int. wipers and stock radio power wont work. When ever im in the car with the doors closed it will say the doors are open on the cluster but when i switch the dome light on and off the door light turns off and when i hit the right blinker my radio will cut out (radio is wired to battery) would most of these problems apply to a bad icu???
Old Nov 18, 2009 | 02:18 PM
Steve-o's Avatar
Default Re: no interior lights work on DA- bad icu?
no ecu prob. maybe bad bcm. or u got a bad short somewere. get a electrical diagram and see what they have incomon and go from there.
Old Nov 18, 2009 | 02:53 PM
icu=interior control unit, ive heard these problems are symptoms of a bad capaciter in the icu.....just lookin for someone whos heard of similar problems before i waste my money
Old Nov 18, 2009 | 08:56 PM
stp_vtec_boi's Avatar
DA's are known for those kinda problems i use to own 2 or them and yeap they are same and no its not the ecu its just that the sensors dont sense anymore or its just not working properly.
Old Nov 19, 2009 | 03:39 AM
the_augie's Avatar
check all the fuses. and check the relays above the interior fuse panel. one may be unplugged?
Old Nov 19, 2009 | 05:51 AM
Alex M.'s Avatar
I just ordered one (ICU) myself for the same problem, should be here by Friday. In my case my rear lights, blinkers, interior lights don't work. Found it on ebay for $30.
Old Nov 19, 2009 | 07:25 AM
hb420's Avatar
Yeah it's the icu. There's a thread on g2ic abou it and the person had the same problems. I have an extra one for sale $15 plus shipping
Old Nov 19, 2009 | 11:03 AM
your from pa hb420? how far are you from ny? im an hour from pa
Old Nov 19, 2009 | 11:09 AM
hb420's Avatar
Less then 2 hours. It takes me about 25 minutes to get to most of the bridges that cross into jersey. Same with the turnpike
duscar
Mar 19, 2011 03:20 PM
miamijdmcoupe524
10
Oct 23, 2005 01:02 PM
TurboJesse
Aug 20, 2003 01:53 AM
