wanting to build 85mm sleeved b18 to get into 11's?
Old Nov 18, 2009 | 12:24 PM
captivateeg6's Avatar
Default wanting to build 85mm sleeved b18 to get into 11's?
Hello,
I am setting myself a challenge to get a n/a b series into the 11's; this is very rare in the uk to do but it's a personal goal for me to do it. I have an eg6 chassis, which is already gutted of its interior circa 2204 ibs (still more to remove/reduce weight on). I am wanting to stay b series to in-keep with the car. This was my build idea:-
b18 block, darton mids sleeves and bored to 85mm
full rotating mass lightened/balanced with knifeedged crank
remove power steering- n1 pulley
lighten flywheel
all new gaskets
uprated oil pump
acl tri-metal bearings
Skunk 2 pro 3 cams, ti springs and retainers
skunk flat face valves
b16 head
5 angle valve job
mild portwork
edelbrook victor-x intake mani
throttle body (70mm??)
high comp pistons (unsure of what compression ratio I will need to run pro 3 cams?)
4.4 transmission
mapped on hondata s300
decent header (ideas?)
with weight down to around 2000 ibs, is it likely I will get anywhere near 11's on mickey thompsons?
Old Nov 18, 2009 | 08:12 PM
ericracingpr's Avatar
Default Re: wanting to build 85mm sleeved b18 to get into 11's?
for the pro3 you will need 12-5-1 and up
Old Nov 18, 2009 | 08:47 PM
mikesrex's Avatar
you should be able to make the power, provided you have a good tuner and a good flowing head. after that, you just need to set the car up right to hook. realistically speaking, you should be able to get 1.55-1.65 60's, provided you have everthing set up right. Good luck on your quest!
Old Nov 19, 2009 | 02:45 PM
the_big_dl86's Avatar
very possible man. i saw a b20 vtec on passtimes last night that was running consistent 11.4s. it wass n/a but not sure of mods.
Old Nov 20, 2009 | 07:03 AM
cool, definately going to aim for it now, 12.5 cr should be doable hopefully on uk 99ron with octane booster, anyone know how do rocket motorsports **** cams compare to the pro 3's? looking to retain some decent mid-range torque as well as the car will be used for some circuit racing also
Old Nov 20, 2009 | 02:52 PM
92TypeR's Avatar
FSAE
Why?
I only ask because my motor has less than 12.5:1 CR and made more power with Pro3's than with Pro2's, BC5's, and two sets of custom grinds.
Old Nov 20, 2009 | 04:01 PM
00Red_SiR's Avatar
All Motor Mentor
Originally Posted by 92TypeR
Why?
because on this site, more is better for everything.
Old Nov 20, 2009 | 04:32 PM
BigBlock22's Avatar
you dont need the knife edged crank... i would consider taking some weight off the crank if i was you but its probably not necessary to have it knife edged.
Old Nov 20, 2009 | 04:52 PM
BigBlock22's Avatar
correct me if im wrong but i thought having a higher compression ratio would help support cams like say the pro3's in its peak rpm range. and at the same time i am not saying the CR decides the cam selection
Old Nov 20, 2009 | 05:46 PM
92TypeR's Avatar
FSAE
Sure, this is a true statement. The more compresssion the more potential the engine has to make more power.
That being said, can you really assign a minimum compression required? At some point, a smaller cam will produce a better powerband, but it isn't a clear-cut defining line. Plenty other variables other than compression go into this, including valve size, efficiency of the cylinder head, induction setup and exhaust manifold.
Old Nov 20, 2009 | 06:50 PM
00Red_SiR's Avatar
All Motor Mentor
While increasing compression will typically result in some power gain to a point, it is most often used to support large cams on a smaller displacement motor. Generally speaking, you can run less compression on a larger motor and still make as much or more power on the same set of cams, than you could running the same cams at higher compression on a smaller displacement motor. Compression is another way to increase airflow through an engine but so is head porting, valve size, intake configuration and exhaust as 92TypeR has said.
Old Nov 20, 2009 | 06:56 PM
BigBlock22's Avatar
i honestly dont think you can assign a minimum compression ratio that will work for every engine. but there are companies that do seem to set a bare minimum requirement. and i agree with you that there are to many variables that come into play when making a selection for the perfect camshaft
Old Nov 20, 2009 | 07:07 PM
00Red_SiR's Avatar
All Motor Mentor
If that's true, then how can it be true to set a single compression ratio for any cam to run on? There's a big difference in airflow between a 1.8 running 12:1 on a set of cams and a 2+L running the same compression on the same cams. I always get a kick out of people that blindly say, "oh as long as you run over 12:1 on those cams, you're good!" ....really...12:1 on any motor huh? any less than that and they won't work? How about 12:1 on a b16a? see how well you do with those cams in there....
Old Nov 20, 2009 | 07:08 PM
lohatch's Avatar
to the OP. i ran a 85x89 setup in my eg hatch at around 2200lbs.
went 12.009@113 before an omnipower valve broke off.
knifedged crank, 13.7:1 comp. small port cyl head with itbs(280cfm head). zex pro race cams. tri-y header, light flywheel, etc on 23" slicks
engine made 205/156 on a mustang dyno with a victorX and 68Tb. never dynoed with the TWMs.
so with the pro series cams you should pick up a little more. and you should be able to get in the 11's with some good chassis prep.
Old Nov 20, 2009 | 07:25 PM
SergEK's Avatar
Originally Posted by captivateeg6
Hello,
lighten flywheel
all new gaskets
uprated oil pump
b16 head
5 angle valve job
mild portwork
4.4 transmission
Why not build an H and go 10's for less money? Curious
Old Nov 21, 2009 | 02:50 PM
lohatch- that's a sick time considering the weight and suchlike
sergek- I have though about h22 but in my mind, I want to keep with the b series as the engine came stock with b16a, I would really like to keep it b and there's the stealth side where people wonder what the hell is done to the engine if it looks fairly stock but goes really well, h series would be more obvious that it is going to be fast, plus I would want a h to b kit if I get the h series and that is quite alot of outlay,
Old Nov 21, 2009 | 02:57 PM
BigBlock22's Avatar
thats exactly what i was saying. not every engine can use the same compression ratio to run on "X" cams. i guess i could of worded it better. perhaps if i said, "i honestly dont think you can assign a minimum compression ratio that will work the same for every engine". since every engine is different especially when we're talking about different displacements. an example of what i am trying to say would be using the same cam on two different size engines, say the pro'2s on a b18 and a h22. skunk2 might recommend using a 12:1 CR for those cams on both engines but we see folks using less than 12:1 on h22s. but the b18 may not perform as well as the h22 while using the same "lower than recommended" CR on a cam like the pro2.
Old Nov 21, 2009 | 03:12 PM
00Red_SiR's Avatar
All Motor Mentor
It might perform better using less compression than the H22 at 12:1 (lets say 11.5:1) if it is using better supporting mods like a professionally ported head, custom header and well matched intake pipe, manifold and exhaust.
92TypeR wasn't trying to suggest there is a single minimum number you can run on every engine, he meant it would vary by the engine and it's unique supporting mods.
Old Nov 21, 2009 | 03:27 PM
BigBlock22's Avatar
right, and i do agree with what he was saying. i think my first response to what he said may have sounded like i did not agree with what he was saying.
Old Nov 21, 2009 | 04:57 PM
SergEK's Avatar
Curious...how much is this build gonna cost you...you can PM me if you dont want to post that info here
H2B adapter is only $750
ChairMachineGun
17
Oct 6, 2009 07:54 PM
scbmx87
118
Apr 7, 2009 11:35 AM
b17 rolla
Sep 26, 2008 07:47 AM
dng
Apr 2, 2004 03:24 PM
Buitrex
Dec 13, 2003 10:23 PM
