Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
GODSPEED PRJECT SUSPENSION AN MORE WITH THE BEST PRICES AROUND
Old Nov 18, 2009 | 02:19 AM
ace_drew1's Avatar
Default GODSPEED PRJECT SUSPENSION AN MORE WITH THE BEST PRICES AROUND
GODSPEED PROJECT TYPE RS DAMPER KIT
applications
HONDA CRX 88-91 TYPE-RS
ACURA INTEGRA 90-93 TYPE-RS
ACURA INTEGRA 94-01 TYPE-RS
HONDA CIVIC 92-95 TYPE-RS
HONDA CIVIC 96-00 TYPE-RS
HONDA S2000 00-08 HYPER-RS COILOVER SUSPENSION
GODSPEED Coil-Over Dampers is the perfect enhancement to your track or street car. Featuring 16 Levels of damper force adjustment, full-height adjustment.
The damper can easily adjusted by turning the **** at the top of the damper. Turning the **** can simply change your daily driving or track day needs. The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can easily raise your car to oem height or lower your car for track performance.
The quality and durability of the GODSPEED Racing Damper kits are made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. we stand by our product with 1 YEAR warranty. (from date purchase. Must be installed by professional tuning shop)
Features:
- Spring Rates: 8kg Front and 6kg Rear
- 16 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
16 Levels of Adjustment:
1-5: Suggested for track use.
6-11: Suggested for mountain/aggressive use.
12-16: Suggested for common street use.
- All Hardware is Included
GODSPEED PROJECT TYPE SS
applications
HONDA CRX 88-91 TYPE-SS
ACURA INTEGRA 90-93 TYPE-SS
ACURA INTEGRA 94-01 TYPE-SS
HONDA CIVIC 92-95 TYPE-SS
HONDA CIVIC 96-00 TYPE -SS
GODSPEED Type-SS w/ Pillowball Upper Mount and Dual Height Adjustments is an high end performance coilover setup designed for everything from daily driving to track competitions. This coilover exhibits superior handling characteristics with the added performance of solid (non rubber) type pillowball upper mounts for an ultra responsive suspension package. Coilovers will come almost ready to install w/o having to reuse stock OEM rubber mounts. This GODSPEED suspension coilover kit offers superior handling, adjustability, and customizability for all your high performance driving needs. .
Features:
- Aluminum Brackets
-All hard ware is included
TURBO KITS
CAT BACK
RADIATORS
Godspeed Rear Cross Bar in stock ready to ship and Pick up!!!
Please dont ask to separate the bar cause we only sell the bar together.
[/B][/SIZE]
unbeatable price!!!
92-95 Honda Civic Hatch EG
GODSPEED CROSS BAR FOR 92-95 honda civic hb (Hatchback ONLY )
-this require minor cutting near the c pillar, attach is the picture to show where it needs to be cut
THIS GODSPEED CROSS IS MADE HIGH QUALITY STAINLESS STEEL ( SUS304)
Godspeed cross bar is born for one function only by connecting the c-pillar and rear upper strut making the rear section of the car act as one thus reducing the flex to zero. It utilizes the C-pillar and strut points to decrease / eliminate body flex during hard cornering. Maximizing 4 critical points of the chassis to 1 stress point. the improvement is undeniable The Godspeed cross bar is the standard of pillar bar & strut bar combined. you will feel the difference instantly after installation. This bar will put your street / show car above the rest.
-note : this require to disconnect the back seat belt. we recommend this item to be use for off-road /show purpose only. professional installation only.
96-00 Honda Civic Hatch (EK)
This comes with the x-cross bar, the bottom strut, top strut and the butterflies for maximum rigidity.
94-01 Acura Ingetra 2dr Hactch All model (dont need to remove rear seat)
customers car on godspeed rs
MY EK ON GODSPEED RS
CHECK US OUT ON MY MYSPACE.COM/TNA_AUTOSPORTS
Old Nov 18, 2009 | 11:46 AM
ace_drew1's Avatar
Default Re: GODSPEED PRJECT SUSPENSION AN MORE WITH THE BEST PRICES AROUND
TTT
Old Nov 18, 2009 | 01:22 PM
ace_drew1's Avatar
bump
Old Nov 18, 2009 | 06:15 PM
ace_drew1's Avatar
ttt
Old Nov 18, 2009 | 07:59 PM
ace_drew1's Avatar
bump
Old Nov 19, 2009 | 06:40 PM
ace_drew1's Avatar
ttt
Old Nov 20, 2009 | 12:32 PM
ace_drew1's Avatar
bump
Old Nov 21, 2009 | 10:32 AM
ace_drew1's Avatar
ttt
Old Nov 21, 2009 | 12:19 PM
b18egchuy's Avatar
Do the eg hatch crossbars come with the optional "butterfly" sides and top and bottom bars?? Lmk. Thnx
Old Nov 21, 2009 | 11:28 PM
ace_drew1's Avatar
pmd bump
Old Nov 23, 2009 | 07:07 PM
ace_drew1's Avatar
ttt
Old Nov 24, 2009 | 01:28 PM
ace_drew1's Avatar
bump
Old Nov 24, 2009 | 02:06 PM
ace_drew1's Avatar
ttt
Old Nov 24, 2009 | 02:33 PM
ace_drew1's Avatar
bump
Old Nov 24, 2009 | 07:29 PM
ace_drew1's Avatar
ttt
Old Nov 25, 2009 | 12:03 PM
ace_drew1's Avatar
bump
Old Nov 25, 2009 | 02:31 PM
ace_drew1's Avatar
ttt
Old Nov 25, 2009 | 04:36 PM
ace_drew1's Avatar
bump
Old Nov 25, 2009 | 08:04 PM
ace_drew1's Avatar
ttt
Old Nov 26, 2009 | 01:52 PM
ace_drew1's Avatar
bump
Old Nov 26, 2009 | 04:31 PM
ace_drew1's Avatar
ttt
Old Nov 27, 2009 | 10:12 AM
ace_drew1's Avatar
bump
Old Nov 27, 2009 | 03:06 PM
ace_drew1's Avatar
ttt
Old Nov 28, 2009 | 09:46 AM
ace_drew1's Avatar
bump
Old Nov 28, 2009 | 10:45 PM
ace_drew1's Avatar
ttt
