custom heatshield?
Old Nov 17, 2009 | 09:00 PM
norcalB18's Avatar
Default custom heatshield?
Does anybody make custom heatshields to hide hytech headers? or is there a way to make the itr heatshield fit?
Old Nov 17, 2009 | 09:02 PM
RiceBurnerRebel's Avatar
Default Re: custom heatshield?
just use exhaust heat wrap.
Old Nov 17, 2009 | 09:57 PM
4g63powered's Avatar
Make a template using some cardboard and either buy the sheetmetal yourself, or find a shop that does one-offs if you can't find one and really need one.
Otherwise I'd just wrap them or get them ceramic coated.
Old Nov 18, 2009 | 12:34 AM
95DC2GS-R's Avatar
Not very good when used on a daily. All that heat under the exhaust wrap between the manifold material turns to steam and thus leaves moisture, which will cause rusting.
Old Nov 18, 2009 | 12:58 AM
EKSiR99's Avatar
have it ceramic coated!!!
Old Nov 18, 2009 | 02:09 PM
norcalB18's Avatar
hmm thats good idea. Ill probably just get them ceramic coated.
Old Nov 18, 2009 | 03:23 PM
TunerN00b's Avatar
I've read this many times, yet the mild steel header on my Spitfire has been wrapped for 16 years now (when I replaced the rusting cast iron manifold with a 4-1 header), and shows no signs of rust. The rustoleum "high temp" flat black paint I used is in much better shape in the areas that are covered by the wrap, compared to the exposed parts. Header was purchased uncoated.
I only wrapped it because the header is 1/2" from the oil pan and 1" under the intake manifold (stupid non-crossflow head), and I was worried about heat.
My personal experience, and only a singular experience. Maybe I just got lucky.
f22b2ecstasy
Aug 7, 2007 10:42 PM
VtecAdil
Welding / Fabrication
11
Jul 15, 2005 01:40 PM
CIVIX
Apr 23, 2004 05:56 AM
Spade
Dec 10, 2001 12:36 PM
00bluSi
Jun 20, 2001 08:55 AM
