Question about GC and Koni
Old Nov 17, 2009 | 07:32 PM
JrEk9's Avatar
Default Question about GC and Koni
hey guys i need ur help, i just got a set of GC but on the box say 94-2001 integra lol, and i have a ej6 lol right now i running with stocks shocks, my question is, i know GC r diferents for koni and stocks shocks, or koni can fit in mines GC ?? if no what shocks can i get ????
Old Nov 17, 2009 | 09:47 PM
fastrxu's Avatar
Default Re: Question about GC and Koni
It says 94-01 integra; but what sleeve does it have? Stock?tokico?koni? What diameter is the sleeve?
That should start you in the right direction
Old Nov 17, 2009 | 09:53 PM
chinochanginc's Avatar
im running gc's for an integra on my EG8... aslong as teh sleeves are for the Koni shock your fine
Old Nov 17, 2009 | 10:55 PM
thumper64's Avatar
They'll fit, don't worry. 94-01 integra and 92-95 Civic are interchangeable.
There are the normal Ground Controls and special ones just for Koni shocks. The normal ones WILL fit Koni shocks, although it's a somewhat ugly looking setup. I've done it, they're on my car and I've ran them like that. You just put the sleeve on the lower spring perch and that's it, it works. Put a couple of the supplied O Rings on your shock body to keep the sleeve from wiggling and you're good to go. I believe the Koni specific sleeves are just a smaller inner diameter. If you have these and shocks that aren't Koni, put them up for trade, they go for more than the normal sleeves new.
To reiterate, the Koni specific ground control sleeves are machined special to fit on the Koni shock directly and look nice. The KYB/Tokico/etc compatible sleeves work if you just set them right on the lower spring perch.
Old Nov 17, 2009 | 11:09 PM
thumper64's Avatar
http://tinypic.com/r/10wij54/6
That will illustrate what I'm trying to explain. People believing you need the "Koni" ground controls to fit Koni shocks bugs me.
Old Nov 18, 2009 | 09:29 AM
JrEk9's Avatar
ok first my ej6 is a 96-98 civic thats why i asked cuz im using 94-01 integra in my 96-98 civic...
but if u said my GC fits in a Koni i'll try i hope work :D lol thks btw....
any more ???
Old Nov 18, 2009 | 10:14 AM
devney's Avatar
edit: nvm
Old Nov 18, 2009 | 01:53 PM
JrEk9's Avatar
Originally Posted by devney
edit: nvm
Old Nov 18, 2009 | 05:09 PM
JrEk9's Avatar
bump^^
Old Nov 19, 2009 | 11:02 AM
JrEk9's Avatar
bump^^
Old Nov 19, 2009 | 11:09 AM
devney's Avatar
What year is your car first of all? And second, do you have the GC's made for koni's or for stock shocks?
Old Nov 19, 2009 | 06:27 PM
JrEk9's Avatar
well my car is a 96 honda civic, and the GC's i got used but in the box said for 94-01 integras, and right now im using the GC's with stocks shocks
Old Nov 19, 2009 | 09:57 PM
thumper64's Avatar
You're good then. They'll fit on Konis just like they fit on your OEM shocks. Not pretty, but it works.
Old Nov 20, 2009 | 09:09 AM
devney's Avatar
Probably not the best way to go about it, but I guess if it's working stick with it for now. Why'd you get GC's for an Integra though?
Old Nov 21, 2009 | 09:25 PM
JrEk9's Avatar
some body sold me for $150 and said those will work with my car
Old Nov 24, 2009 | 08:00 PM
JrEk9's Avatar
bump^^^^
Old Nov 24, 2009 | 08:55 PM
thumper64's Avatar
What did you bump this for? You got your answer.
Diamond Co
Suspension & Brakes
May 11, 2012 11:26 AM
kevinm1981
Suspension & Brakes
10
Jul 12, 2009 01:13 PM
alex_s817
Suspension & Brakes
May 3, 2006 07:09 AM
integerkgsr
Feb 21, 2004 10:52 AM
ek6-crvtec
Apr 6, 2002 10:26 PM
