Coolant woes
Old Nov 17, 2009 | 07:23 PM
macson's Avatar
Default Coolant woes
Hey everyone, could use a bit of help with this
98 civic ex
165k miles
Only mods are Apexi WS2 catback, Megan racing 4-2-1 header
Anywho, the car seems to lose coolant, not sure where it's going. Rad is fairly new (replaced a little over a year ago). No visable leaks or any smoke whatsoever. It's not losing it very quickly, I'd say maybe a quart over 2 weeks or so. Strange thing is that the reservoir never goes dry, it actually is almost always completely topped off, even if I empty it down to the low line. After a few days at the latest it's back up to the top. Maybe something with the cap? Maybe it's just burning it? Any thoughts? It never overheats, occasionally it will start to creep up a bit if I'm at a standstill when it ends up getting low on coolant. Weird thing is that the fan will at best only occasionally switch on it's not completely dead, just comes on when it feels like it, have to check that out as well. =\
Old Nov 18, 2009 | 12:04 PM
macson's Avatar
Default Re: Coolant woes
Bump?
Old Nov 18, 2009 | 12:41 PM
ShevyA's Avatar
Since you say their are no leaks, id say your engine is burning coolant. Try changing the headgasket
Old Nov 18, 2009 | 12:50 PM
JasonYo's Avatar
Maybe the water pump leaks only when you're driving.
I know mine does, because I never have coolant on the ground when I park, and my coolant level goes down progressively. When I finally checked it out there was some coolant drops around my water pump. I still need to change it tho, kinda lazy.
Old Nov 18, 2009 | 01:28 PM
macson's Avatar
I'll check out the water pump, it could most definitely be that. I'm not sure if the previous owner replaced it around 100k miles, but I know I haven't done so yet. Thanks for the tip.
Old Nov 18, 2009 | 02:01 PM
Sr420Det's Avatar
Does the motor every seem to skip or blow white smoke (especially when u first crank it up), if so its probably the hg
Old Nov 18, 2009 | 02:21 PM
macson's Avatar
No smoke that I've ever noticed. If anything, just the little bit of steamy "smoke" when it's really cold out, like most. I'll take another look tonight when I start it up, just to double check.
Old Nov 18, 2009 | 05:51 PM
300whpej's Avatar
changed your thermostat or hoses lately?
lfunk11
Honda Civic (2001 - 2005)
Jan 16, 2012 12:34 AM
ham
13
Feb 13, 2007 10:04 AM
BubLBack
Oct 5, 2006 09:47 PM
som3on3_10
Mar 29, 2006 03:31 PM
92integraVTECgsr
Aug 27, 2005 02:44 PM
