FS: Brand New Jim Justice Built B20VTEC
B20 with block guard
P72 oil pan
ITR crank and rods
All new parts, pistons, rings, bearings, oil and water pumps
GE head studs
B16 Head Fully Ported
Custom Web Cams
New valves and springs
New rocker arms
GE adjustable cam gears
This engine was orginally built by DFE for NASA H1 and put down around 215-220whp. It was used on the street for about 400 miles. When NASA allowed the use of a block guard for the B20s in H1, the engine was taken to Jim Justice. There is was completely torn down, block guard installed, cylinders honed and block decked. New rings and bearings were installed. Head was fully dismantled, cleaned and seats touched up. New rocker arms were installed as were reworked Web cams and valve stem seals. New valves were installed previously by DFE. Cam timing was set. This was done early this year and the engine has never been started. So you are getting a fresh built B20 by one of the top engine builders in the country. Engine has been oiled, fog and rotated periodically.
$4,500
540-414-6908
P72 oil pan
ITR crank and rods
GE head studs
Custom Web Cams
New rocker arms
$4,500
540-414-6908
