Spark Plugs and Spark Plug Wires
Old Nov 17, 2009 | 06:13 PM
LS_VTECteggy's Avatar
Default Spark Plugs and Spark Plug Wires
Ok so I have a b18b ls/vtec, I don't know which spec of spark plugs to buy, the gs-r or the ls, another question is the spark plug wires, since I have vtec do I buy the gs-r spark plug wires or the ls spark plug wires. Planning to get NGK spark plugs and wires, but don't know which specs to go with so to sum it all up
    Old Nov 17, 2009 | 08:58 PM
    Ricextacy's Avatar
    Default Re: Spark Plugs and Spark Plug Wires
    gsr everything.
    Old Nov 17, 2009 | 09:22 PM
    PaulMc's Avatar
    Painfully Stupid
    Go with GS-R spec everything, it's all basically the same. NGK is the best way to go too.
    Old Nov 18, 2009 | 12:41 AM
    AllMotorDC4's Avatar
    It's a GSR head>Gsr plugs & Wires.
    Old Nov 18, 2009 | 12:53 AM
    EKSiR99's Avatar
    ngk bkr7
    Old Nov 18, 2009 | 05:55 AM
    Jimmy's Avatar
    Global Moderator
    I recommend NGK Blue plug wires with NGK plugs
    Old Nov 18, 2009 | 06:11 AM
    ok so now I know what specs to get do you recommend iridium or platinum spark plugs and as for spark plug wires how comes the gsr why does it cost more than the LS wires both are going to be NGK
    Old Nov 18, 2009 | 06:32 AM
    dpetro1's Avatar
    Wires:
    NGK Part# HE64 (more expensive cause they are mAd TytE V-tech yo! )
    Plugs:
    Standard Copper - NGK Part# BKR6E-11 (stock# 2756) @ $2.75 a plug
    Iridium - NGK Part# BKR6EIX-11 (stock# 3764) @ $7.50 a plug
    Only real difference between plugs is that Iridiums last for like 100k miles where as the standard go for about 6-10k. Technically the standard copper v-power plugs have better conductivity, they are cheaper but need to be changed more. Your call.
    Also stick with the 6 heat range unless the car is heavily modified (turbo, nitrous, high compression). Running a plug that is too cold will make them foul out more quickly and wont provide any perfomance gains.
    I recommend www.importrp.com for all your ngk needs. they have great prices.
    Old Nov 18, 2009 | 06:45 AM
    alright thanks my man I just ordered the best parts, the NGK iridium and NGK spark plug wires, 106.79 total again thanks for all of the help guys
    Old Nov 18, 2009 | 06:59 PM
    ok now a new problem has popped up when I was just sitting around thinking, since the spark plug is in a vertical direction, how am I suppose to bring it out, there is nothing to cling onto the spark plug so any suggestion, I do know that there is the spark plug socket but is there another way to take it out without buying the socket?
    Old Nov 18, 2009 | 08:38 PM
    stp_vtec_boi's Avatar
    Yea you use a 5/8 deep socket and 1 of your spark plug wires to get the spark plugs out when you unloosen them there you go cheap and fast lol.
    Old Nov 18, 2009 | 09:17 PM
    Ricextacy's Avatar
    and make some local honda friends.
    Old Nov 19, 2009 | 04:53 AM
    dpetro1's Avatar
    a socket is like $5 and will save you a bunch of time. putting them back in will be way easier with the spark plug held into the socket. if you want to work on cars you need the right tools, the proper socket is well worth the money
    Old Nov 19, 2009 | 07:35 AM
    alright ill just buy the socket and the feeler gauge and btw what is the difference between a spark plug socket and a regular socket?
    Old Nov 19, 2009 | 08:18 AM
    GagnarTheUnruly's Avatar
    It has a rubber bit inside of it that grabs the spark plug and lets you screw and unscrew it. It's a good idea to use one because cross-threading your spark plugs can be bad news, and the spark plug puller gives you more control over the plug, helping you to line it up and thread it properly.
    Old Nov 19, 2009 | 03:05 PM
    Jimmy's Avatar
    Global Moderator
    A spark plug socket has a rubber gasket in it that holds onto the plug, normal socket.. does not.
    Old Nov 19, 2009 | 04:19 PM
    alright thanks guys
    OrangeTeggy
    Apr 4, 2009 12:43 PM
    SoyMilk
    Jun 3, 2007 04:45 AM
    Xymox007
    Jul 30, 2004 11:42 AM
    EM1_GIL
    Mar 23, 2004 05:31 PM
