92 ex hart to start when cold
Old Nov 17, 2009 | 05:14 PM
tkda's Avatar
Default 92 ex hart to start when cold
motor is a d15b7 with that ecu, i have tryed the p28 aswell. and replaced the fuel pump.
when the car has been sitting for multiple hours i will have to crank it for 10 seconds then it will start and die then start and die then start and almost die, then 5 seconds later it will pick up and run, but if i hit the gas it will almost die so i have to let it sit for a minuet or two.
any ideas on what this could be. thanks
Old Nov 17, 2009 | 07:55 PM
tkda's Avatar
Default Re: 92 ex hart to start when cold
bump
Old Nov 18, 2009 | 12:08 AM
HCivExoo's Avatar
bump for a good question. this could be a couple different things i think. if it runs good after warming up i wouldn't think that it is an ignition issue. I would try checking your IACV possibly? jsut make sure it is gummed up. also your FIAV if it is not opening that could be causing your cold running/ starting issues.
other ideas chime in to help this guy out
Old Nov 21, 2009 | 07:17 PM
tkda's Avatar
yeah i will check those out and clean them up.
any idea's? fuel filter?
Old Nov 21, 2009 | 07:19 PM
king29's Avatar
Icon2 Re: 92 ex hart to start when cold
when was the last time you did a full system tune-up?
Old Nov 22, 2009 | 01:04 PM
tkda's Avatar
i did cap and plugs 2 months ago.
Old Nov 22, 2009 | 02:14 PM
king29's Avatar
Icon4 Re: 92 ex hart to start when cold
is it getting spark? have you tried replacing the dizzy? i had an accord old school that was doing the same problem, i would have to get lucky for it to turn on first time cranking, but i'd have to give it gas for it to stay on if not it wouldnt turn on at all :/ , i replaced the distributor and it worked like a champ, maybe it could be the same problem for your car?
Old Nov 23, 2009 | 12:18 AM
jdm.coupe3234's Avatar
my first del sol had this problem.. i let out all the gas from my tank.. but vpower gas.. put a fuel system cleaner by b-12 and changed out my fuel filter.. and it would turn on way better after that
Old Nov 24, 2009 | 02:22 PM
tkda's Avatar
thanks for the advice, ill get a fuel filter and check back later
Old Nov 24, 2009 | 03:07 PM
loudandlow's Avatar
Buy a bottle of Lucas fuel treatment, wait till your gas light turns on put in 5 gallons and the treatment and drive it until the light comes on again. Then fill up with midgrade.
If it's not that, start looking at spark if you already replaced the pump.
greenwave12
Jun 27, 2015 06:51 AM
Bones82
Honda Civic (2001 - 2005)
Oct 14, 2010 07:15 PM
gandalf
Aug 24, 2009 04:39 PM
hondaboy4life
May 8, 2006 06:44 AM
bigbacon2
Jun 27, 2005 10:58 AM
