Anybody use this t3/t4 cast manifold?
Hello everyone. Has anyone here used this manifold or know anyone who has used it? It's an ebay cast. I want to know if a .58/.63 t3/t4 will fit in my 99' Si without having to shave the block. If you know where I can see pictures or if you can post pictures of the manifold installed on a 99-00 Si that would be great. Thanks in advance.
Looks just like my manilfold.... B18B with a .63 Precision T3
please excuse the HUGE filter.. it was temporary as my mini filter was being cleaned.
if the turbo has a 4-bolt exhaust discharge there may be block shaving requried, 5-bolt should clear just fine (maybe a small notch to webbing)
Thanks alot guys. It looks like it'll work. I'm running a t3 right now and want to run a t3/t4 but my manifold won't clear the block with the bigger turbo. If anyone else wants to give referance feel free to do so.
what mani do you have now?
are you running it with the compressor on the passenger side? (AC compatible)
what turbo do you have? (4 or 5 bolt exhaust?)
That looks like the blox not the inlinepro. Inlinepro is stainless steel not cast iron.
I used the Blox with a Peakboost Blowzilla and no shaving except we turned the turbo around so it would stick out to radiator side.
The manifold I have now was made by a local tech. It's a/c compatible, mild steel, and is tubular and I'm running it with the compressor on the passenger side. The turbo is a Nissan .60 t3, 5 bolt exhaust, internal wastegate.
h22turbolude
Dec 10, 2003 09:30 AM
Ri5e
Oct 17, 2002 03:51 PM
