b16a2 in an eg, mounts?
Old Nov 17, 2009 | 03:06 PM
smokinloc's Avatar
Default b16a2 in an eg, mounts?
im goin to be putting a b16a2 with a 96 gsr tranny into my 1993 civic. wat power steering pump, alternator, starter, and dizzy should i get to use with it? i am going to run a obd1 p30 ecu, and want to run the car on obd1.
and also wat mounts should i use? i have heard that stock DC mounts are a direct bolt in, is that true? any help would be much appreciated, i have tried to search but have come up with no answers so far
Old Nov 17, 2009 | 07:13 PM
smokinloc's Avatar
Default Re: b16a2 in an eg, mounts?
anyone?
Old Nov 17, 2009 | 09:00 PM
es01civy's Avatar
stock dc mounts do fit
Old Nov 17, 2009 | 10:37 PM
98civdx's Avatar
Master Detailer
dc mounts will work but im 90% sure you will need to change the drivier side mount bracket aswell. i think integras/eg are 3 bolt and 96-00 is 2
Old Nov 18, 2009 | 02:04 AM
es01civy's Avatar
title says into a eg dc mounts will fit and no change for the bracket
Old Nov 18, 2009 | 09:23 AM
smokinloc's Avatar
alrite thx for the help, im gonna pick up a set of dc mounts soon, but im still looking for answers as far as wat starter, alt, power steering pump, and distributor should i use? obd1 b series? or should i get them for a 99 civic sir? cuz thats where my motor is originally from
Old Nov 18, 2009 | 10:17 AM
98civdx's Avatar
Master Detailer
[QUOTE=es01civy;40674880]title says into a eg dc mounts will fit and no change for the bracket[/QUOTE
im not blind, and i know how to read,
everything from obd1 integra will work for you.
Old Nov 18, 2009 | 11:05 PM
es01civy's Avatar
[QUOTE=98civdx;40678088]
OBD2 too
Old Nov 18, 2009 | 11:27 PM
smokinloc's Avatar
alrite, im goin to be running a p30 obd1 ecu so would it just be easy to get everything for a obd1 integra so its just a plug and play system?(aside from wiring vtech) or obd2 integra parts do the exact same?
Old Nov 19, 2009 | 10:11 AM
98civdx's Avatar
Master Detailer
obd1 will be plug and play. i belive obd2 is not and you will eiher need to switch plugs or get adapter harness, it will be easier to stick to obd1
NAcoupeNA
Jul 16, 2014 02:43 PM
SlowReaction
Northwest (Sales)
16
Jun 8, 2011 08:14 PM
marcusgnf
Mid-Atlantic (Sales)
Mar 25, 2010 12:55 PM
Boosted B6teen
Dec 7, 2005 07:41 PM
