Help...loud exhaust? (EM1)
Old Nov 17, 2009 | 01:20 PM
Evilwayz24's Avatar
Default UPDATE: Help...loud exhaust? (EM1)
My EM1 has a stock exhaust and at regular street driving is relatively quiet. However, on the highway at high rpms/speed the exhaust just recently has become much much louder. I checked the exhaust and the catalytic converter and there are no visible holes anywhere.
Anyone know why my exhaust is so loud, is it the catalytic converter? Any other ideas?
Thanks
Old Nov 17, 2009 | 01:55 PM
ballisticej1's Avatar
Default Re: Help...loud exhaust? (EM1)
Most likely a hole somewhere in the piping or a gasket thats all worn out. Just gotta get under it and inspect all of it :/
Wisconsin weather sucks for things like this
Old Nov 17, 2009 | 05:03 PM
boxeocampeon's Avatar
you probably do have a hole somwhere where you cant see. i had one and i swear i checked like five times but we finally found it when it was put up on the rack
Old Nov 17, 2009 | 07:10 PM
tamadrumr88's Avatar
my DX had this problem recently and was only getting worse. the rear muffler was rusted out at the weld just before the muffler and it eventually worked its way loose
autopartswarehouse.com has a pretty decent deal on OE-replacement exhausts if that's what you're looking for. I replaced everything after the cat for under $150 and did the work myself (that includes a resonated mid pipe and rear muffler). Granted it's not stainless steel but it works and I probably won't ever have to replace it again. Meineke wanted $160 just to make a new rear muffler... lame
find the hole and get it re-welded for $20 at a local exhaust shop if it's a minor job. if it's a complicated job it'd probably be easier/cheaper to just find a used aftermarket exhaust on here
Old Nov 17, 2009 | 08:32 PM
Sutterlude's Avatar
check where the piping goes over the rear lower control arm mine rusted threw on my em1 and sounded like nascar at 70mph
Old Nov 18, 2009 | 02:25 PM
importdreamer's Avatar
Now that it's getting cold enough, start it and look for the exhaust coming out. A little quicksteel should fix it for a short while.
Old Nov 18, 2009 | 02:45 PM
backyard_concepts's Avatar
x2
Old Nov 18, 2009 | 03:49 PM
20-EM2-05's Avatar
This happened to my brothers 240sx like 4 years ago. Like everyone said, check your pipings, there is a hole somewhere.
Old Nov 19, 2009 | 10:55 PM
96honda_EK's Avatar
Haha bro you just over reacting. Its your vtec haha
Old Nov 19, 2009 | 10:59 PM
eesuh's Avatar
lmao ^^
Old Nov 20, 2009 | 04:20 AM
EuroStar Tech's Avatar
New User
check the donut gasket before the "test pipe" area
Old Nov 20, 2009 | 02:32 PM
20-EM2-05's Avatar
Lmaoo. I never knew 240's came with Vtec. Haha.
Old Nov 20, 2009 | 11:17 PM
96honda_EK's Avatar
Ugh ok who said we're talking about a 240? Look on the first post. It says EM1. And just in case you didnt no, an EM1 comes with a doch vtec motor. So nice try but maybe next time
Old Nov 21, 2009 | 01:34 PM
Evilwayz24's Avatar
Took apart the entire exhaust and no visible holes anywhere...still going to replace the exhaust regardless. Any other ideas?
Old Nov 22, 2009 | 04:21 PM
Did you find anything with the cold weather test? Did you pull the heat shield on the header? You should see some black soot gathering around any possible crack in it.
Old Nov 22, 2009 | 05:34 PM
Dontoh's Avatar
hahaha, don't get mad, get glad
Old Dec 3, 2009 | 11:05 AM
Evilwayz24's Avatar
UPDATE: We would hear a loud humming noise when we drove around 30-40mph. Thinking it was the exhaust we replaced it. It was not...turns out it was actually the right rear wheel bearing that was causing that noise. About a $100 fix.
JDMCL
Honda CR-V & Element
Jan 29, 2014 07:42 PM
Mikes2000civicsi
23
Dec 24, 2006 12:27 PM
Ding
24
Oct 24, 2005 11:28 AM
jagged4698
Dec 31, 2004 01:19 AM
KRNewbie
Mar 18, 2002 07:19 AM
