Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
OEM cd player problems
Old Nov 17, 2009 | 01:15 PM
I Kick Squirrels's Avatar
Default OEM cd player problems
My girlfriend got an 06 si a few months back and everything has been working fine with not the first problem....today when she is leaving school her cd player starts making the ticking noise and will not load in a new cd.
Has anyone here had this problem or have any input as to what I could do to fix it.
btw its just a single disc cd player
Old Nov 17, 2009 | 06:19 PM
pd0019's Avatar
Default Re: OEM cd player problems
i've only ever had this problem when the cd im playing isnt in mp3 or wma format. check to see if she burned itune files or something.
Old Nov 17, 2009 | 07:15 PM
SpoonFedEj8's Avatar
I would run with pd0019, sometimes cd players are picky.
Old Nov 18, 2009 | 06:03 AM
im sayin that the CD player wont even take the cd in the slot....like there is no motor pulling it in if you get what im sayin. I cant hear the motor tryin working but nothing is grabbing the cd into the player
Old Nov 18, 2009 | 05:23 PM
speedracer9k's Avatar
the only thing you can do now is replace the audio unit. if it's still under warranty they will replace it for you, or they can send it out to get repaired if it's not under warranty.
Old Nov 18, 2009 | 09:25 PM
Is there a cd stuck in it? Its more of a hassle than its worth. Id get a new cd player, it sounds like the motor in your cd player might be fried. Slot loading cd players use a motor to load and eject the cds, so if it is not loading then your motor might be busted. But you mentioned that it is making a "ticking noise" so your motor might not be messed up, instead it might be stuck. If you have the cd player out of your vehicle you could crack it open and see what might be going on. But to save you the hassle, I would suggest buying a new one or if it is still under warranty have it replaced.
winne
Audio / Security / Video
Mar 29, 2011 01:03 AM
jdmcd7_cali-luv
Dec 19, 2008 02:05 PM
97EK9hatch
Jan 12, 2005 08:14 PM
Norcalstoppy
Aug 6, 2003 10:02 PM
