big brake kits suggestions/help
Old Nov 17, 2009 | 01:06 PM
gosu08's Avatar
Default big brake kits suggestions/help
My car is making more power and I am needing to upgrade my brakes.
I am making 450 whp and 320 torque right now.
Does anyone have any recommendations or experience with any big brake kit?
Thanks.
Old Nov 17, 2009 | 03:43 PM
n2mports's Avatar
Default Re: big brake kits suggestions/help
I have the Wilwood 6 piston front calipers with 12.9" rotors and they seem to work ok. Alittle over kill for me. I haven't really had a chance to test them out either. I also did the rear with there single piston caliper and 12.9" rotors but mainly just for looks.
Hope that helps. Most might tell you to get new pads and brake lines though. So i hope you searched first.
Old Nov 17, 2009 | 08:08 PM
gosu08's Avatar
ive searched some but i want some personal experience.
Old Nov 17, 2009 | 09:29 PM
highroller54's Avatar
I have a used mugen kit if your interested.
Old Nov 17, 2009 | 10:53 PM
slofu's Avatar
The Mugen Active Gate kit uses the S2K brakes (11.1" X 25mm rotors). On a road course, the speed the OP is likely to see with his power is going to require something considerably bigger, for better heat dissipation. He might start with the 12.6" X 28mm Acura RL brakes, a good set of Carbotech pads, and proper ducting. Before my car was stolen, I was happy with my Legend GS 11.1 X 28mm brakes, but like most here, I wasn't making 1/2 the OP's power.
Old Nov 19, 2009 | 03:17 AM
gosu08's Avatar
would replacing the stock rotors to brembo cross drilled rotors help out any for both the front and rear?
is it worth it at about $400?
or should i save up for a big brake kit?
Old Nov 19, 2009 | 05:53 AM
Rus1an's Avatar
I used to have a Integra with the Rotora kit and it was amazing, could stop on a dime.
Old Nov 19, 2009 | 09:50 AM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
Waste of money IMO. Just get blanks, fluid with a high boiling point, good pads and make some break vents.
Old Nov 19, 2009 | 09:52 AM
Ausmith's Avatar
What are you using your car for?
Old Nov 19, 2009 | 12:12 PM
gosu08's Avatar
just straight line. no auto X.
Old Nov 19, 2009 | 03:21 PM
n2mports's Avatar
Oh... well in that case just get a parachute. LOL
Old Nov 19, 2009 | 10:23 PM
gosu08's Avatar
haha im not that fast. still on bone stock motor yay!
Old Nov 19, 2009 | 11:04 PM
slofu's Avatar
Which is it?
If you don't drive it hard, stock brakes will suffice. For what I do, with that power I'd eventually get these: http://www.stoptech.com/Products/BBK/summary.shtml
Old Nov 19, 2009 | 11:09 PM
gosu08's Avatar
Originally Posted by slofu
Which is it?
"i am not that fast" was referring to the post that i should get a parachute instead lol
and yes i am on stock motor putting down 450whp and 320 torque
i have looked into those stoptech brakes but they are quite expensive....
Old Nov 20, 2009 | 08:10 AM
slofu's Avatar
Boosted on stock internals. Got it.
If you're just drag racing, a good set of pads on the stock brake system should provide plenty of braking torque, and the rotors won't have to dissipate heat as quickly as if you were road racing. Also, I realize that most drag racers don't want to use >15" wheels, and you're likely not going to fit 15s over brakes much larger in diameter than stock.
Old Nov 20, 2009 | 01:44 PM
Splat's Avatar
Collector-o-Guns and Drinker
Better pads.
Old Nov 21, 2009 | 12:23 PM
ixoiiiiviviiivi's Avatar
Could always go with Rear drums and a 40/40 Proportioning Valve. I think they're more responsive with handbraking over rear discs as well. +1 for stopping power -1 for looks. Also try slamming on your brakes. If they lock up your brakes are overpowering your tires so you will not need to upgrade them if not then your tires are overpowering your brakes and you should upgrade or bump up the stopping power of the fronts and rears.
Old Nov 21, 2009 | 02:18 PM
gosu08's Avatar
guess i will get better pads for now and see how that does.
does anyone recommend any. a person once suggested hawk pads. any other suggestions?
Old Nov 21, 2009 | 03:38 PM
beat's Avatar
if you go with hardcore pads, its better to get some better rotors too, race spec pads will eat up original rotors in no time
Old Nov 22, 2009 | 02:53 PM
slofu's Avatar
Carbotech AX6 is a great all-around pad. For most purposes, rotors costing anything > NAPA replacements is a total waste of $. For my track car I kept getting my [redrilled] Autozone rotors replaced annually under warranty. Can't beat free.
Old Nov 23, 2009 | 12:15 AM
jdm_dc_fan's Avatar
this guy knows what hes talking about. dont buy into those expensive aftermarket rotors. autozone rotors get the job done and theyre cheap.
Old Nov 24, 2009 | 02:59 AM
gosu08's Avatar
ok looks like pads with high dot brake fluid for now then when my rotors start to get worn then ill get some autozone rotors.
thanks
Old Nov 27, 2009 | 01:59 PM
gosu08's Avatar
with carbotech AX6, can i buy those locally at say autozone or pepboys?
any suggestiosn for pads that i can pick up locally?
Old Nov 27, 2009 | 07:00 PM
1tuffbb6's Avatar
Check out EBC.
Old Nov 28, 2009 | 02:22 PM
slofu's Avatar
UPS is your friend:
http://www.thmotorsports.com/carbote.../i-241069.aspx
EBC may have changed their compounds, but a few years ago the general consensus was that they were ****.
Denis aka CiViC4dr
Nov 13, 2004 04:12 PM
clin20
Jun 7, 2004 08:30 AM
garados
Apr 23, 2002 04:48 AM
Short_Shifter
Dec 27, 2001 12:57 PM
Reverend
Aug 30, 2001 08:16 AM
