HELP!! Check Engine Light Stays on constantly!!
alright, here we go:
I was throwing a code 6 and a 36 (I know, doesnt exist, but it really did throw a 36) anyways, spent all day fixing the code 6, now when I turn the key, the batt light stays on, I hear the main relay and fuel pump kick in, I have spark, I have flooded my cylinders, but they are dry now. what gives? all fuses are OK. I rechecked my powers and grounds on my wiring, check the ICM, all the dist wires, everything SEEMS ok.. so what should I be looking for other than tearing the whole harness out and starting over?
BTW: this is a 96 dx hatch, with OBD2 to OBD1 harness, p13 (JDM) ecu, H22a
please help!
please help!
um, this helped me once:
unplug the battery for at least 10 minutes...
(unless you already have tried "the master reset")
what was the code 6 - what did you fix?
t..
t..
code 6 was the ECT, engine coolant temp, I thought it was on the radiator hose neck behind the engine, turns out its on the head, under the distributor.. so I learned soemthing there.. I will try that.. if that doesnt work, I'm gonna rip the WHOLE DAMN THING OUT and spend the day rewiring and double checking..
thanks!
thanks!
hunter fitch
Engine Management and Tuning
Feb 1, 2019 11:12 AM
BigBlockCRX
Sep 2, 2002 12:03 PM
