Clutch problem?
Old Nov 17, 2009 | 08:56 AM
Zteve's Avatar
Default Clutch problem?
I'm not too sure anyone can help with this one.. I have a 95 Accord and have recently noticed a squeak coming from the clutch. The only reason I know it's the clutch is because when I rest my foot on the peddle the squeaking stops. Now this only happens after the engine is warm. I'm also having a problem getting into 3rd and 5th if I run up to 4500rpm and try to go into those particular gears. It's chatters a little, and sometimes a lot... Also the clutch is less than 2 months old..
Old Nov 17, 2009 | 10:45 AM
craiger28's Avatar
Default Re: Clutch problem?
did you replace all components in your clutch?? i.e. pressure plate, clutch plate, throw out bearing, etc....
Old Nov 17, 2009 | 10:47 AM
craiger28's Avatar
oh btw, it sounds like the noise you hear is your throw out bearing....
Old Nov 17, 2009 | 03:45 PM
Zteve's Avatar
The clutch was just done before I bought it.. You can tell it's new buy the way it grabs.. I'm going to obviously have to take it back to where it was done..
Old Nov 17, 2009 | 04:32 PM
nus_dogg's Avatar
I want to say its a Pilot Bearing but Accords don't have them like Civics/Tegs do. So I would think its your Throwout Bearing; since, it would press on the diaphragm springs also called fingers which is on the pressure plate.
Old Nov 18, 2009 | 08:46 AM
Zteve's Avatar
Update..
The noise is a squeaky clutch arm LOL.. so that's good.. But still can't figure out why it chatters into 3rd and 5th when I'm trying to accelerate at a high rate of speed...
petty$rep
Oct 31, 2006 08:45 PM
BABY NSX
Jul 17, 2006 09:14 PM
JdmFront619
Oct 28, 2003 12:25 PM
ludelvr
Sep 28, 2003 11:02 AM
viperguy
Aug 14, 2003 11:59 AM
