Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tire/Rim fitment question on 09 SI
Old Nov 17, 2009 | 06:10 AM
accordianex's Avatar
Default Tire/Rim fitment question on 09 SI
I just got an 09 Civic SI 4 Door and its about to snow here in WNY.
A guy is selling a set of rims off a 2003 Accord V6 with 205/60R16 snow tires.
I know that its the same lug pattern of 5x114.3 but will they work?
Also tirerack says to go with 205/55R16 if i go with 16" rims. Will the tire size work as well?
Thanks for any input.
-ian
Old Nov 17, 2009 | 06:17 AM
judgeDredd's Avatar
Default Re: Tire/Rim fitment question on 09 SI
they should be fine with only a 16" wheel
Got this off 8thgen Hopefully can get sticky
Si/Coupe
16x7 50mm offset 205/55-16 (No drop)
17x7 45mm offset 215/45-17 (Stock Si Fitment)
17x7 40mm offset 215/45-17 (No drop)
17x7 55mm offset 215/45-17 (1.5" Drop)
17x7.5 38mm offset 225/40-17 (1.5" drop)
17x7.5 42mm offset 225/45-17
17x8 45mm offset 235/40-17
17x8 42mm offset 235/40-17 (1.4" drop w/Eibach Sportlines)
17x8 35mm offset 225/45-17
18x7.5 40mm offset 225/40-18
18x7 45mm offset 215/40-18 (HFP Wheel Fitment)
18x7.5 50mm offset 215/40-18 (No Drop)
18x7.5 50mm offset 215/40-18 (1.5" drop)
18x7.5 45mm offset 225/40-18 (1.4" drop)
18x7.5 +35 offset with 225/40/18s
19x7.5 44mm offset (3mm spacers installed {41mm effectively}) 225/35-19 (Lowered 2.25" Tein SS)
19x8 40mm offset 225/35-19 (Dropped on HFP springs .5" drop or Tein SS 2.25" Drop)
20x7.5 45mm offset 225/30-20
20x8.5 35mm offset 225/30-20 (1" drop w/Eibach Prokit)
Sedan
17x7 35mm offset 215/40-17 (No Drop)
17x7 42mm offset 225/45-17 (lowered on Eibach Pro Kit)
17x7 55mm offset 205/45-17 (Lowered 2" Neuspeed Springs)
17x7 45mm offset 205/45-17 (Lowered 2" Neuspeed Springs)
17x7.5 45mm offset 215/50-17
17X8 43mm offset 225/45-17 (Lowered on Eibach Pro kit)
18x8 48mm offset 225/40-18
18x8.5 +45 offset with 255/35/18....yes, 255s! (stock TL upgraded wheels)Lowered on Tanabe DF210s
Old Nov 17, 2009 | 06:27 AM
Thanks, will the center hub opening play any role in this? and the offset?
Or since they are both Honda it should be good?
Old Nov 17, 2009 | 06:43 AM
judgeDredd's Avatar
i think the brake size may play a role if anything is to get in your way the si has big brakes an may hit.
Old Nov 17, 2009 | 07:02 AM
S2Carbonworks's Avatar
Si/Coupe
Sedan
All the math done for you
Lil_Wyte
Feb 25, 2007 02:38 PM
Bastion
Dec 7, 2005 05:54 AM
doubledown
May 21, 2003 09:47 PM
MRDC2
Feb 21, 2003 05:33 PM
mattL
Jan 17, 2002 08:44 AM
