98 accord tire size
Old Nov 16, 2009 | 08:53 PM
z395civic's Avatar
Default 98 accord tire size
i have a 98 accord lx sedan. i do ALOT of outdoor things like camping, hiking, hunting, and fishing. 99% of the fishing access roads where i live are ALWAYS very very muddy and "rugged" if you will. i have gotten stuck a couple times over the summer with my summer tires and i was wondering if anyone knows what the largest tire size i can fit on my accord without it rubbing would be? i know the stock size is 196/65/15. please dont tell me to buy a tuck and so on, i was close to buying a 03 subaru forester but i decided not to. the accord is already paid for and i just put a new engine in it, long story short, i plan to keep it for a while...
Old Nov 16, 2009 | 11:13 PM
YeuEmMaiMai's Avatar
Default Re: 98 accord tire size
car has open differential so that has more to do with you getting stuck. getting a limited slip will go a long ways towards solving your problem
Old Nov 17, 2009 | 06:43 AM
z395civic's Avatar
ehhhhh....a LSD is not cheap, around $800......has anyone ever ran 205/70/15 or 205/75/15?
Old Nov 17, 2009 | 07:18 AM
TheMuffinMan's Avatar
He knows where you live!
And new tires are ~$400 + install
Are you at stock height?
Old Nov 17, 2009 | 07:22 AM
z395civic's Avatar
yes i am at stock ride height.
Old Nov 17, 2009 | 09:06 AM
While I have not personally run anything with that tall of a sidewall you can do a quick google search for "miata tire size calculater" and enter the stock size tire then enter the one you want.
It will tell you how off your speedometer will be as well as the difference in size between that and stock. You could use that to measure.
Old Nov 17, 2009 | 06:54 PM
z395civic's Avatar
when i go from 195/65/15to 205/70/15
sidewall 5.0" to 5.6"
radius 12.5" to 13.1"
diameter 25.0" to 26.3"
circumference 78.5" to 82.6"
none of the changes seem to be that big but im not a tire expert. i THINK i can run the 205/70/15. what do you think?
Old Nov 17, 2009 | 07:00 PM
It doesn't seem like *that* much of a difference, however keep in mind that sidewall difference is on both sides of the tire. So you have .6" more in all directions.
I would say from the numbers you *look* ok but I would wait for someone else to chime in before you pull the trigger on them. I'm more familiar with CD chassis Accords.
Old Nov 17, 2009 | 07:11 PM
z395civic's Avatar
im going to measure tomorrow and see what i think from there. if no one on hear has an answer for me im going to bite the bullet and go to a junk yard, see if i can find 2 tires in that size, run them in the front and if they dont rub, switch them to the back and see if there are any problems.
Old Nov 17, 2009 | 08:53 PM
z395civic's Avatar
just to give u an idea. this is "entrance" to one if the fishing access roads lol. the actual access road is ALOT worse. sometimes i wonder how i dont get stuck more often lol. you might ask yourself, "it looks like you are going kinda fast in that picture, why in the hell are you doing that?" i tried to go through the access road at a normal speed, didint quite work out, so what you see is my "running start"
Old Nov 18, 2009 | 02:42 AM
i'd gladly pay that $800 if it meant i would not get stuck.......after all $800 is cheaper than a truck
SlamsItIn
Dec 12, 2013 02:50 PM
z395civic
Jul 5, 2009 10:25 AM
shibbywhitedude
Jan 13, 2007 11:18 AM
blackpearlv6
Apr 21, 2006 11:42 AM
eg686
Sep 2, 2005 03:15 AM
