Suspension & Brakes Theory, alignment, spring rates....
Car pulls to the right when I take off.
Old Nov 16, 2009 | 08:10 PM
nite82hawk's Avatar
Default Car pulls to the right when I take off.
Hi. I have a 07 civic si that recently started pulling to the right when I start from a stop. It doesn't pull when I let off the gas. The only thing recently that could've done it was I hit a 6" "bump" on a construction zone going about 40 but it didn't starting pulling about a month after that. So what could it be?
Btw, it's not torque steer. This is happens when I take off normally. Thanks.
Old Nov 16, 2009 | 10:31 PM
Tyson's Avatar
Default Re: Car pulls to the right when I take off.
you need an alignment.
Old Nov 16, 2009 | 11:12 PM
jdm inc's Avatar
^^ agree when u hit that bump prob threw the alignment off.
Old Nov 16, 2009 | 11:45 PM
nite82hawk's Avatar
What's funny is that I took it to Sears auto to get it checked out and they said that that wouldn't be an alignment issue. They checked it out anyway and said that the front was just a tad off but not enough to make it do that and (the kicker) there was no way to adjust them because Honda didn't make the front adjustable
I was wondering, if it was out of alignment, wouldn't it also pull to the right even without gas being applied??
Old Nov 16, 2009 | 11:50 PM
Tyson's Avatar
what were the camber caster and toe readings exactly?
if its excessive cross camber or cross caster, then its not easily adjusted. but then you at least know whats needing to be replaced ( control arm, or whatnot).
Old Nov 17, 2009 | 12:12 AM
nite82hawk's Avatar
I got to find the sheet. I'll post it later, thanks.
Old Nov 17, 2009 | 07:10 PM
nite82hawk's Avatar
Here is the sheet. Do you guys think this would be an alignment issue?
Old Nov 17, 2009 | 07:36 PM
vietjdmboi's Avatar
i would look into the right rear camber. maybe something is bent?
Old Nov 17, 2009 | 10:45 PM
Tyson's Avatar
that left rear toe definitely explains why it turns right. especially in take off when you load the rear tires.
i dont know why they would recommend not to fix it.
but whats up with your caster? why is it so high?
Zuheir
Honda CR-V & Element
Feb 22, 2016 02:22 PM
m R g S r
Honda S2000
May 11, 2007 02:41 PM
chewtext
Sep 19, 2005 04:07 AM
chewtext
Suspension & Brakes
Sep 15, 2005 08:59 AM
joedaddy
Aug 15, 2005 09:04 PM
