obd1 distributor conversion help
Old Nov 16, 2009 | 12:49 PM
98gsr-808-91dx's Avatar
Default obd1 distributor conversion help
sorry i know thers tons of threads out there but im lost. i got a obd1 dizzy from a 92 civic dx. i trying to put it with my y7 in my 91 dx. thye obd1 dizzx plug has 7 wires while the dpfi obd0 harness i hav from the dx only has 5 wires. i know most the wires match with the colors but short 2 wires? if any1 can please help. was thinking just gotta run 2 wires to the ecu?
Old Nov 16, 2009 | 06:06 PM
Bigdaddy3314080's Avatar
Default Re: obd1 distributor conversion help
you need to do a obd1 conversion which usually intails a new ecu and a jumper harness
Old Nov 16, 2009 | 07:46 PM
crx_si-r's Avatar
first things first. is your car already mpfi? if not are you going to re-use your obd0 DPFI manifold? if so then simply re-use your old distributor. if you are going to actually use the 92 DX distributor then you will have to do an mpfi conversion as well as an obd1 conversion.
Old Nov 17, 2009 | 08:44 AM
freeagent's Avatar
having the same problem but telling someone they need to do the swap doesnt help.
tellus what has to be done for the two extra wires..
ive got the obd1 jumpers and trying to do the mpfi conversion but ive not read anywere on what to do about this
Old Nov 17, 2009 | 09:50 AM
4drEF's Avatar
Keyboard Humorist
They are the C1 and C2 wires that get added to the dizzy wiring.
http://hondaswap.com/swap-articles/d...writeup-49557/
Old Nov 17, 2009 | 10:37 AM
pin B10 & B12 should be emptycan use pins from B2 & B11 as well. Cut and move C1 to B10 and C2 to B12. Leave a few inches of wire from ECUU. Run WIres from the C1 & C2 that are cut to the engine compartment for the dizzy. the C1 goes to the blue/green and C2 goes to the bluue/yellow on the dizzy plug.
Also must swap the outside 2 wires on the TPS
and then the injector wiring, but depends if they are high or low Impedence
Old Nov 17, 2009 | 12:24 PM
freeagent's Avatar
ok cool thanks good to know..
now my question is how do i tell whats what on the ecu as far as b10 and c1 and all those i cant find a link to tell me whats what
ok lol i clicked the link and found what i wanted thanks again!
Old Nov 17, 2009 | 12:53 PM
freeagent's Avatar
ok so i have a red and white wire in pin b12? im kinda stumped
Old Nov 17, 2009 | 03:17 PM
4drEF's Avatar
Keyboard Humorist
Some cars have that wire.
It will NOT effect anything to get rid of it and move along with your conversion.
Old Nov 17, 2009 | 04:36 PM
freeagent's Avatar
ok..btw im not tryin to thread jack..lol but i hope im helpin by askin these questions..
and i got the dizzy wiring done a couple hours saudered everything next ill tape all the wires up so they are covered in black then ill put that plastic stuff around them to give the factory look..wish me luck on the injector part!
OemED
19
Oct 10, 2016 08:19 AM
KevinEF7
Oct 29, 2012 01:15 PM
Tensa_Zangetsu
23
Nov 23, 2008 08:09 PM
Ruby Civic
Dec 11, 2003 04:07 AM
Steve91
19
Aug 28, 2003 03:44 PM
