What kind of power SHOULD I be making?
I havent been to the dyno yet so I am curious what kind of numbers you guys think I should be pulling on this setup;
Turbo B18A obd0 stock bottom end
Mild head porting
Crower cams
T3/4 Turbo (not sure the exact specs) @ 10lbs boost
450cc injectors
Also, where is the limit on the stock bottom end?
Mild head porting
Crower cams
450cc injectors
the stock bottom end will probably take more then those injectors will put out... Ive seen personally a couple 300whp bone stock B18b's with a mild setup... but they used bigger injectors then that..
I wouldnt risk it
I wouldnt risk it
vtecgod
Oct 8, 2007 12:41 PM
nokturnal_munkeeboy
Apr 24, 2007 09:14 AM
Freeltec
May 4, 2004 04:30 PM
