Advice need on parts to replace ( Doing Timiing Belt)
you can also replace the oil pump, depending on how worn the motor is or how many miles are on mine. timing cover gasket if yours is dry and cracking. other than that i think that is it. unless you wanna do the thermostat as well? if you need a new water pump n tensioner pm me.
water pump, water pump gasket, tensioner, tensioner bolt, timing belt cover gaskets, valve cover gasket, and that's about it.
reno96teg
Apr 25, 2006 05:06 AM
idriveadelsol7
Dec 8, 2005 06:00 AM
B18Redline
Nov 6, 2004 10:26 AM
