Seeking advice/suggestions with this fresh build's problem.
Old Nov 15, 2009 | 08:49 PM
DC4KiD's Avatar
Default Seeking advice/suggestions with this fresh build's problem.
all resolved. thanks for those who helped!
Old Nov 15, 2009 | 09:06 PM
OUT OF ORDER ROB's Avatar
Default Re: Seeking advice/suggestions with this fresh build's problem.
Help Help Help
Old Nov 15, 2009 | 09:38 PM
gsp ej1-em1's Avatar
dood, just tow it to your tuner and have them fix it. it could just be the tune after all.
Old Nov 15, 2009 | 09:42 PM
YARO.'s Avatar
I agree with tune x2!!!
Old Nov 16, 2009 | 05:27 AM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
bump. have a pretty similar problem and its frustrating as FAWK!!!!!!!!!!!!!
Old Nov 16, 2009 | 05:32 AM
kyden's Avatar
do you have a wideband?
Old Nov 16, 2009 | 02:21 PM
hybrdthry911's Avatar
blox c cams, no tune of course its gonna run like ****.
Old Nov 16, 2009 | 03:22 PM
DC4KiD's Avatar
I'm on a TUNED ECU with the MATCHING GM 3BAR MAP Sensor. I understand that not all engines run the same even if they're nearly identical in setup, but Blox C cams themselves ain't gonna make my car mis-fire like crazy and fouling out my plugs.
kyden - I don't have a wide-band.
Old Nov 16, 2009 | 06:40 PM
you put an aggresive cam in your car and expect it to run good. not sure what there is to misunderstand here. the car is untuned, an ecu from another car thats been tuned is not considered tuned.
Old Nov 16, 2009 | 08:14 PM
DC4KiD's Avatar
Look, I'm not expecting it to run perfect, I just want it to run good enough for me to drive the car to the tuner. So what you're saying is, the crazy mis-firing is expected? ****, I hope not because I've installed cams in other cars (and my car with a prevous setup) and drove it UNTUNED OK just to get to the tuner. My car is UNDRIVEABLE to get to the tuner because of the problem.
And those cams aren't even that agressive; their profile is less than the B/Stage 2 cams.
Old Nov 16, 2009 | 09:33 PM
i love ht. you ask for help and they give you criticism.
Old Nov 17, 2009 | 12:37 PM
i love HT too. someone asks for help you tell them what could be wrong and they tell you, you are wrong.
Old Nov 17, 2009 | 01:48 PM
NonovUrbizniz's Avatar
Loved
It sounds like an ECU problem... I'd try swapping in a stock ECU just to see if it will drive in gear OK... obviously don't go into boost... but if the problem is it's breaking up AS SOON as it's in gear and you try to drive it... chances are the maps are not setup right for your car.
Also you didn't give any relevant information...
WHAT ECU?
In what way is it "tuned"
What was your friends setup that ran fine with it? same motor/trans? same obd?
It's almost certainly your ECU or map.
Old Nov 17, 2009 | 06:57 PM
DC4KiD's Avatar
Yeah... but what's so legitimate about "you have blox c cams, of course it's gonna run like ****"?
I know what it's like to run on aftermarket cams with a stock ECU, base map, and a tuned map from another car, and it's definitely not like what I'm experiencing right now.
WHAT ECU?
It's a chipped P28 dyno tuned with Crome on my friend's EK (2.0L C1, 469whp/382trq), both the MAP sensor and ECU are from that car, and were working just fine right before I pulled them out.
I have another chipped ECU that I can try swapping out the maps just incase one of them has been short-circuited some how.
It's boiling down to either the ECU or my wiring harness, since I did re-wrap it and did some soldering. I'm gonna open it up, and hopefully I'll find something obviously wrong (LOL).
Appreciate the advice!
loopedR6
Oct 10, 2006 10:15 AM
turbo98lude
Jul 7, 2005 02:40 PM
no2unenolife
Jan 25, 2005 06:20 AM
JFG Kevin
Sep 23, 2004 09:09 AM
