92 eg d16 engine noise?
sounds like when ur powersteering is low and you turn the wheel. except its constant not only when turning.
so i thought the pump was going out, but i pulled the powersteering belt and the noise was still there any ideas?
i was thinking water pump but i hope not.
One of your drive belts, my bet is the alternator belt is loose and it makes that loud annoying screeching noise. Tighten the belt and that should solve your problem.
http://www.youtube.com/watch?v=zkcq7jttO5g
got that vid. you can hear it best at the end.
ac compressor giving up.SOLVED
just need a confirmation pretty sure its one of these:
AC compressor/alternator (taking off belt to check after this)
TimingBelt/Tensioner
Input shaft bearing(dont think so because sound comes from timing belt side)
let me know what you guys think. thanks.
i finally pulled the ac belt and the compressor was the problem.
this sound was caused by an ac compressor on its way out
well atleast its drivable, but a timing belt and tensioner woulda been cheaper to replace.
hopes this helps someone while they're searching thanks guys. HONDA-TECH
was about to do an oil change was gonna use some Castro high mileage. green bottle would that be good?
oh and when u say valve tap.... whats the valve tapping against?
october_red
Nov 22, 2008 10:07 AM
