B18A swap questions
Old Aug 31, 2002 | 07:16 PM
FourthGenHatch's Avatar
Default B18A swap questions
I am strongly considering this as my engine swap. I know a guy with Si EF and he said he run a 15 flat once and he isn't really a racer or anything so I'm sure I could get into a high 14 which is more than fine for me.
Basically I wanted to know how much it would cost for everything I need and where can I get this engine, it's from a 90-91 Teg (possibly 90-93). And I want to do the swap myself but I won't attempt it without some good instructions, so where could I get some?
Old Aug 31, 2002 | 08:25 PM
rioninja's Avatar
Default Re: B18A swap questions (FourthGenHatch)
You'll want the motor from a 90-91 teg, since honda switched to obd-1 as of 92. You pretty much want the entire drivetrain: complete motor, trans, intermediate shaft and axles. Also, make sure you get the distributor, alternator, and the L shaped rear motor mount bracket.
If your car is an SI, all you need to do is remove the entire engine harness from your stock motor and wire it up to the LS. Its a tight squeeze in places, but it fits without too much trouble.
For the instalation, the easiest way is to purchase a mount kit such as Hasport or HCP. I recommend the HCP over the hasport. Its cheaper, and comes with the shift linkage.
Old Aug 31, 2002 | 08:34 PM
Default Re: B18A swap questions (RioNinja)
I have a DX so will I need all that stuff and then the HASport DPFI > MPFI harness and thats it?So it's not that hard really?
Old Aug 31, 2002 | 10:50 PM
Speed PHreak's Avatar
http://www.geocities.com/speed_phreak_88hf/how2swap.htm
Read through that, it'll answer a good many of your questions.
Knowledge IS power
Old Aug 31, 2002 | 11:33 PM
hybridhatch90's Avatar
Default Re: B18A swap questions (Speed PHreak)
the swap has to be the eaisest out there. i love mine. did it in a day with my friend. hasport mounts are sick! i have a si, so it was just plug and play. ive the 92-93 motors are better. i have a 93, the only thing you do is get a pr4 ecu, a 90-91 dizzy, and use si injectors. the complete swap with a brand new in box clutch was $1200.
Old Sep 1, 2002 | 12:20 AM
Jeff 360's Avatar
Default Re: B18A swap questions (hybridhatch90)
hybrid hatch is most correct. I've seen the HCP mounts and Hasport mounts up close and personal. I do like that HCP are cheaper...but remember in this business you get what you pay for my Hasport mounts are about 5 times...(and I mean that literally)thicker than the HCP mounts. With the torque from the LS...I promise you'll break an HCP mount. I'm currently droppin' my LS in and I will post pics galore of before during and after of course. Here's a pre shot
Old Sep 1, 2002 | 09:34 AM
rioninja's Avatar
Default Re: B18A swap questions (Jeff 360)
The HCP mounts are made of steel. The reason your hasport mounts are thicker is because they are aluminum, so that HAVE to be thicker so they dont break. There are a ton of people on here that have broken Hasports old aluminum mounts, but you never ever hear of people breaking a HCP mount. If you get hasport, get the new billet kit.
I have nothing against the Hasport, but telling people the hcps are junk is uncalled for, since you dont have any facts to back that up.
Old Sep 1, 2002 | 11:39 AM
Losrocket_'s Avatar
HASport doesnt offer anyhting but the billet mounts now.
Old Sep 1, 2002 | 04:28 PM
88hondahatch's Avatar
funny how HCP's break so easy w/ a b20 in a CRX
funny how the HAsports are just fine.........
Old Sep 1, 2002 | 04:50 PM
ThatRicerDaniel's Avatar
the best place to get help is on a board. dont attempt it unless your mechanically inclined, and have a all the tools you need.i dunno about out there but in cali you can pick up the complete b18a1 swap for about a grand. plus plan on spending a couple hundred on liitle stuff.
Old Sep 1, 2002 | 05:58 PM
Default Re: B18A swap questions (NitrousDreamz)
I'm pretty mechanically inclined, I have yet to fail any task I have set out to do on my car so I have a good record now.
Old Sep 1, 2002 | 06:08 PM
Where did you guys get your engines from?
Old Sep 1, 2002 | 07:10 PM
samiam's Avatar
try www.jspecjdm.net
Old Sep 3, 2002 | 10:15 AM
rioninja's Avatar
Default Re: B18A swap questions (88hondahatch)
Funny how you dont even own a B20. Funny how this post is about an LS swap, not a B20. Funny how HCP mounts hold up fine for so many people w/ heavily boosted motors, including my own. Funny indeed, Mr acura-honda.net moderator.
Old Sep 3, 2002 | 11:52 AM
Funny how I never get props for my write up.......ingrates
Old Sep 3, 2002 | 09:09 PM
rioninja's Avatar
Props to speekphreak (happy now )
And dont worry about the swap, its not much harder than replacing a stock motor.
Also, check the tech sections at http://www.hasport.com .
Old Sep 3, 2002 | 11:25 PM
Hotrod Honda's Avatar
I have a 92 LS in my 89 Si hatch and I did 14.6 with it and it's low on compression and the total cost for me in CAN funds was just under 1200 for the motor and new clutch and HASport mounts. We did the swap in 4 hrs with 3 ppl and was easy to do.....
Old Sep 3, 2002 | 11:37 PM
brbHPR's Avatar
Default Re: B18A swap questions (Hotrod Honda)
hey hotrod honda, have you dealt with redshift before?
Old Sep 4, 2002 | 01:43 PM
Rob!'s Avatar
Default Re: B18A swap questions (brbHPR)
ok there are opinions on different parts...who cares...just help the man out...i need help too im trying to swap a b18a into my 91 hf. help me too!!!
Old Oct 7, 2002 | 05:18 PM
performula's Avatar
Holy...that is quick for stock!
What ecu?
Old Oct 11, 2002 | 02:30 AM
Default Re: B18A swap questions (performula)
SAWEET I did the same time with my LS and low compression..... 14.6@92MPH and I have a 89 Si also
[Modified by Hotrod Honda, 3:30 AM 10/11/2002]
Old Oct 11, 2002 | 07:19 AM
Mugen Dom's Avatar
some one was owned rioninja knows alot more than u people would beleive being he never posts....bu he works alot and works on his car even more....just call him mcgyver he can do anything with some duct tape
Old Oct 11, 2002 | 08:03 AM
Hybrid CRX's Avatar
New User
Default Re: B18A swap questions (RaceFacer)
HEY racefacer!
post pictures of your car!
Old Oct 11, 2002 | 03:52 PM
Taco Sauce's Avatar
Knowledge IS power
thats an awesome site. i wish i would have known about it before i started my swap in febuary (and i'm still not done). a nine month swap gets to be really demotivating. good luck on the swap hopefully i'll know how the car runs really soon.
Old Oct 11, 2002 | 04:10 PM
shortyz's Avatar
Default Re: B18A swap questions (JDMFIEND)
whats the price difference in mounts guys? cause i mean if HCP is way cheaper and ive heard many people using them on here, why not? both mounts have broken. no one really knows which is better.
someone should set up a test with a torque bar and the mounts.. i duno..
hyrev20
Nov 3, 2008 07:13 AM
CornerCarvin
May 12, 2007 03:03 PM
FireMedic
May 28, 2003 09:38 PM
rocket_R
May 2, 2002 11:32 AM
