turboed ls fuel management
Old Nov 15, 2009 | 03:45 PM
gabe768's Avatar
Default turboed ls fuel management
ok im buying a turbo kit tomorrow and it comes with everything except the fuel management.
what are my options? im looking to run about 6 psi of boost and i obviously dont want any detonation...can i just run some higher octane fuel or what?
any or all options help alot
thanks guys
Old Nov 15, 2009 | 04:29 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: turboed ls fuel management
Any of the Hondata options, neptune, AEM, etc. Do it right, spend the money where it matters, which is on tuning so the car runs correctly.
Heck Even a Greddy Emanage would suffice for you.
Old Nov 15, 2009 | 05:59 PM
g2daturbo's Avatar
hondata 4 sure but for low boost almost anything will do.. emanage...crome neptune..just wanna make sure u tune it... there is also the afc hack but thats not the (right) way to do it.
Old Nov 15, 2009 | 06:49 PM
gabe768's Avatar
problem is is i have a 2000 integra. (OBD2)
i dont think hondata makes an obd2 system does it?
Old Nov 15, 2009 | 07:27 PM
Mattb16teg's Avatar
Community Builder
conversion harness, very simple
Old Nov 15, 2009 | 08:15 PM
gabe768's Avatar
what would happen if i didnt get a tune?
could i install it and run higer octane fuel for now until i can afford a piggy back system?
Old Nov 15, 2009 | 08:52 PM
a97b18b's Avatar
don't install it until you can get something to tune w/ cuz you could end up having to fork out another 3 grand for another motor
Old Nov 15, 2009 | 09:02 PM
gabe768's Avatar
http://www.phearable.net/shoppingcar...ages-p-63.html
is that a s100 system that you can tune? or is it just something you need...
can you not just get your stock ecu tuned?
and also, is crome a program that you download and tune your stock ecu or is it a piggyback system like hondata or aem ems?
and finally, can you just buy a chipped ecu and have it tuned w/out a piggyback system?
Old Nov 16, 2009 | 04:15 AM
Mattb16teg's Avatar
Community Builder
I'd say dont risk it by running the motor untuned, despite it being a mild setup.
No you cannot tune the stock ECU, there is no gui or tunable parameters within a stock ECU, things like a VAFC are the lowest form of tuning without physically modifying your ECU.
All the other programs you mentioned will require you to chip your ECU to run them.
I would say just try to find a S100 System as it would be cheaper.
Old Nov 16, 2009 | 07:05 AM
DDTECH's Avatar
Crome, ectune , neptune, are better / cheaper then hondata, and offer the same ****..
Old Nov 16, 2009 | 09:34 PM
gabe768's Avatar
if im doing all of this do i NEED an upgraded fuel pump/injectors and the GM 3 Bar MAP sensors?
or can i just run it all on stock?
Old Nov 16, 2009 | 10:46 PM
DDTECH's Avatar
IF your asking me this question, your not ready to do what your about to do..
Read alittle bit more into it.. you dont need a GM 3 bar..
But from a professional standpoint i'd upgrade your fuel pump and injectors..
Old Nov 18, 2009 | 08:56 PM
gabe768's Avatar
could i get a pherable chipped ecu where they add a basemap specifically for the vehicle and mods, and run my turbo kit on that until i get enough cash to get everything else?
http://www.phearable.net/shoppingcar...vtec-p-32.html
Old Nov 18, 2009 | 09:08 PM
stp_vtec_boi's Avatar
here's what you need dsm 450cc injectors, go cheap apexi neo, walbro 255 fuel pump, wide band, boost gauge, and later in the future a hondata but neo will do for now.
Old Nov 19, 2009 | 04:21 AM
Mattb16teg's Avatar
Community Builder
Originally Posted by stp_vtec_boi
here's what I think you could use dsm 450cc injectors, go cheap apexi neo, walbro 255 fuel pump, wide band, boost gauge, and later in the future a hondata but neo will do for now.
Fixed!
Old Nov 19, 2009 | 01:35 PM
gabe768's Avatar
what about the Missing Link with a fuel pressure regulator and a walbroh 255 lph fuel pump?
Old Nov 19, 2009 | 02:36 PM
DDTECH's Avatar
Old Nov 19, 2009 | 06:36 PM
gabe768's Avatar
well is it "bad"? like whats the issues with it? it will just be temporary for a month or two
Old Nov 19, 2009 | 07:14 PM
Mattb16teg's Avatar
Community Builder
What is this "it" you are referring to?
You really need to do some research, the knowledge base here on HT is extensive. Search in the https://honda-tech.com/forums/engine-management-tuning-124/ section as well.
Once you do some reading get back to us, then you will realize how half assing and "going the cheap" route isn't going to get you anywhere.
Old Nov 19, 2009 | 07:22 PM
gabe768's Avatar
im referring to the missing link
and i have been searching, thats why i posted my own thread to answer questions i couldnt find
and i dont have the money to fork out 200 for s100, 250 for a tune, 150 for an ecu, 75 for obd2 to obd1 converter, 80 for fuel pump, and 80 for fuel pressure regulator
i want my turbo kit on and i dont even care if i get 15hp i just want it on so i can enjoy it, and if the missing link is an option until i can fork out the cash for all the other **** then ill take it
i just wanna know if it causes problems because from what ive found in my research havent found anything bad besides people saying "you need to get hondata" but they NEVER explain why
i mean im talkin like maybe 3 weeks, i just found on xenocron a kit that comes with the conversion cables and crome pro for 400...so it wouldnt be a long time runnin with the missing link and im gunna need a fuel pump and fuel pressure regulator/bigger injectors anyway
Old Nov 19, 2009 | 09:56 PM
grndcont's Avatar
Pm'd. I have all that for sale.
Old Nov 20, 2009 | 04:11 AM
Mattb16teg's Avatar
Community Builder
Chill and do it right, why rush into it using junk products???
So just because you can't wait to get it on, you want to risk blowing up your motor? patience > New motor................
Trust me, I've been there, wait and do IT RIGHT!!
Old Nov 20, 2009 | 06:17 AM
Mattb16teg's Avatar
Community Builder
Perfect example, used Hondata, good price:
http://www.hondamarketplace.com/show....php?t=2683182
Old Nov 21, 2009 | 04:32 PM
so what are your current mod's at the moment?
Old Nov 21, 2009 | 10:29 PM
gabe768's Avatar
short ram, headers, cat back exhaust, short shifter, lowered, c/f hood, drilled/slotted rotors
