Itr cluster into an ek anyone know of a how to guide ?
Hey all
can anyone point me in the right direction as to a do it yourself sort of wiring thing or do it yourself install guide on the itr cluster swap into an ek ?
Thanks in advance
-Lee
Thanks in advance
-Lee
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-97-98-01-integra-cluster-into-92-95-96-00-civic-wiring-diagrams-1053318/
please search before making a post next time.
Thanks.
Thanks.
Okay so I followed that how to guide to the letter, a bunch of stuff is messed up .... dimmer works, get the nice type r orangey backlight, rpm works..... that is until I turn the signals on then it jumps up and down... so I checked my wiring again ... all of it was exactly to the wiring diagrams from the link above... it's a 94-97 itr cluster into 1996-2000 civic. so RPm jumps when signal is turned on, fuel gauge is out of wack .. only had a half tank before and now it reads past full, everything on my stock cluster worked 1000000% fine. every light every function.
any one any ideas ????? did I get a messed up ITR cluster......
-Lee
-Lee
-Lee
BUMP ....
anyone heard of these clusters being "broken" and could cause problems.... my stock cluster worked perfect ... I moved the wires around as per the thread I found on the cluster swap which people have confirmed works..... so do you guys think my jdm itr cluster could be shorted??
-Lee
-Lee
9kB20
Sep 6, 2005 03:58 PM
