V-AFC pics
Old Aug 31, 2002 | 07:09 PM
Boostless97Lude
Guest
Posts: n/a
Default V-AFC pics
looking for pics of custom mount jobs of V-AFCs..... thinking of removing my clock and putting it there since my headunit has a clock on it. has anyone else mounted it there???? where else have you guys mounted it???
Old Aug 31, 2002 | 07:44 PM
Tweakmeister's Avatar
Default Re: V-AFC pics (Boosted97Lude)
it works there in front of the clock (dunno about sun). I would not expose the unit for long periods to the sun....
above rear view mirror....right behind shifter...or my favorite.... in the glovebox.
Old Aug 31, 2002 | 07:45 PM
EleanoR's Avatar
Glove compartment and that way no one knows you have it other than yourself!
Old Aug 31, 2002 | 08:21 PM
Tiwe's Avatar
whats a V-AFC?
sorry i'm a noob and i'm still learning ****...
Old Aug 31, 2002 | 08:28 PM
Eric R's Avatar
Default Re: V-AFC pics (Tiwe)
It is a electronic device that allow the user to adjust the vtec engagement point (rpm) and to adjust the fuel delivery at many points along the rpm spectrum at 500 rpm increment. Also adjust the fuel settings in low and hi cam stages (leans or enriches the fuel mix) i.e: Adds power. Very useful for moded engines.
[Modified by Tweety R, 9:32 PM 8/31/2002]
Old Aug 31, 2002 | 09:06 PM
Tiwe's Avatar
Default Re: V-AFC pics (Tweety R)
ok so if i set the thing to VTEC from 1 rpm then will i get VTEC all the time?
Old Aug 31, 2002 | 09:13 PM
Big Teggie's Avatar
Here is where I mounted mine. Right under the radio.
Old Aug 31, 2002 | 09:55 PM
nEoMuGen's Avatar
Default Re: V-AFC pics (Big Teggie)
Did you photochoped the above pic? I have mine install on the same location, but that V-AFC of yours looks awfully big and out of proportion.
Old Aug 31, 2002 | 10:16 PM
Big Teggie's Avatar
Default Re: V-AFC pics (nEoMuGen)
Thats the way it is. The pic makes it look big for some reason. But looks really small in person.
Old Sep 1, 2002 | 02:41 AM
comptechgsr's Avatar
all about the angle
Old Sep 1, 2002 | 09:19 AM
Default Re: V-AFC pics (comptechgsr)
Yes, but this is a very foolish thing to do. Vtec is in place so that you get good low-rpm torque and gas mileage >> and then after a certain rpm it allows for a more aggresive cam profile (vtec engages) which doesn't offer good low end torque or gas mileage.
Read this: http://www.team-integra.net/sections...p?ArticleID=45
Old Sep 1, 2002 | 09:43 AM
onyx00's Avatar
Default Re: V-AFC pics (Tweakmeister)
Glove compartment. You can see it easily and when you open the glove at night the light in there shines on the V-AFC, looks great.
Old Sep 1, 2002 | 11:59 AM
sneakychaos's Avatar
whats a V-AFC?
VTEC Air Flow Converter... aka a piggyback Fuel Computer.
See : http://www.apexi-usa.com for more information.
Old Sep 1, 2002 | 12:13 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: V-AFC pics (trooth)
RStoR's install:
My install:
Old Sep 1, 2002 | 12:30 PM
DC2R714's Avatar
Default Re: V-AFC pics (Splat)
Here's my install. Just have to shave a little off the cig lighter.
[Modified by DC2R714, 9:31 PM 9/1/2002]
Old Sep 1, 2002 | 01:46 PM
blackANESE's Avatar
No, the lowest you can set the vtec switchover on these is at 3k rpm.
Plus, it is useless to do so.
Old Sep 2, 2002 | 01:13 PM
maxim's Avatar
Default Re: V-AFC pics (blackANESE)
I have the wierd connector on there for taking it on and off when leaving the car in questionable places. Without the VAFC connected the car will idle rough, then die.
[Modified by maxim, 4:15 PM 9/2/2002]
Old Sep 2, 2002 | 01:22 PM
Splat's Avatar
Default Re: V-AFC pics (maxim)
Nicely done! Good security measure.
Old Sep 2, 2002 | 03:28 PM
PM-Performance's Avatar
heres a pic of mine, just follow the link , or if someon can host it for me, wetodddid wont work for me .
http://www.imagestation.com/picture/...c/fd571691.jpg
Old Sep 2, 2002 | 03:33 PM
EpDarks's Avatar
Default Re: V-AFC pics (itr206)
That looks cool!!!
I'd say I like the visor one the best.
Old Sep 2, 2002 | 03:35 PM
Default Re: V-AFC pics (EpDarks)
thanks man , i do like the visor one too . did you have to do something to the backside so it doesnt stick out the back , but flush with the front?
i know its thicker than the visor
GreenR's Avatar
Default Re: V-AFC pics (DC2R714)
THat's were mine is too once you shave alittle off of the lighter, it will sit flush with everything else.
Old Sep 2, 2002 | 04:07 PM
ALL THINGS R's Avatar
Thats f--nn awsome!
sicsol
Old Sep 2, 2002 | 04:18 PM
4-1-1's Avatar
Default Re: V-AFC pics (sicsol)
Can you disconnect and reconnect the vafc system everytime your in and out of the car?
Old Sep 2, 2002 | 05:20 PM
maxim's Avatar
Default Re: V-AFC pics (4-1-1)
Yes, I do that all the time and it doesn't mess up the settings. The VAFC unit has the setting saved in it everytime you turn off your car, so it will work if you disconnect it and reconnect it everytime. Just make sure you have it plugged in before you turn the ignition. I did that one time and got a CEL code because the connector wasn't in all the way. Was no big deal though.
The only problem I have is when passengers want to put the passenger side sun visor down. The section where the male and female connector plugs together is on the bottom of the visor(female connector velcro'd there). This prevents the sun visor from going down all the way.
Here are some more pics for those that asked me about the connector and mounting the unit:
- 12 pin male and female video connector
