lowered the 4door and other things
Well I had the chance to do some more things to the 4 door on Saturday, and MAN IM HAPPY
Did new front rotors and pads
New Tein Springs
JDM Sprt LCA's
Syncromesh tranny-fluid
Dont dawg the rims, They are loaners till i pick up some HX'z, THESE RIMS HAVE BRAND NEW TIRES, FTMFW!!
Well The before "stock height"
And the after I LOVE TEIN!!! "had em on my accord!!
TEIN
The LCA'S
New Tein Springs
JDM Sprt LCA's
TEIN
The LCA'S
yeah, in the instructions it says something abouth cutting the bump stop, but I wasnt for sure on what they were trying to get at, so i left it the way it was, but i wouldnt mind seeing it drop a bit more
give it a try...if you need to get some new bumpstops then follow the link below...!!!
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-petsmart-bumpstops-2203422/
^^^ trust me, as soon as I do my y8 head swap and block rebuild, the HX's are one of my top things to get. buuuuut
some more good news, MY....
water pump and timeing belt for Y8
oil pump
piston rings
and rod/main bearings came in
PLUUUUS i got the MPFI intake manny $30 and Si harness $20 last night
Now all i need is for my y8 head gasket set to come in, I need it so I can get my valve job done so they can throw in the valve seals
I need to buy a 91 si dizzy, sum obd0 injectors and rail, plus pm6 ECU and resistor box
then it will be offical!!!
A few questions,
will the resistor box from a crx hf work for me?
and if i get the injectors from a DA, will the fuel rail work aswell? NEED HELP THANK YOU!
oil pump
piston rings
A few questions,
DA fuel rail won't line up.
HF resistor box will work assuming you use low impedance injectors.
Why not use the Y8 intake manifold and injectors?
but more good news My gasket set JUST CAME IN!!! YESSSS head is going to shop for valve job 2morrow!!!
There is no such thing as OBD specific injectors - only high impedance and low impedance.
If you want to run high impedance then delete the resistor box.
You can use the Y8 manifold with your OBD0 ECU.
op, remove the dust shield on your shock, and i dont usually run bumpstops at all, some people cut them in 1/2, but usually your UCA will hit first before the shock bottoms out.
well if im using the 91 si MPFI manny and 91 crx si harness and 91 si dizzy and pm6 ecu, on a Y8 head, what injectors and resistor box can I use,
I am hitting up a junk yard today or 2morrow
I know the DA injectors will work, will the resistor box work aswell?
and can i use a 92-95 fuel rail off a civic?
SWEET i picked up a few parts for the swap today, I spent $65
but i got more parts
The valve cover was $25 and was coated already, the junkyards wanted $30
Ecu was 40
Ecu was 40
What can i do to get the front about a 1/4 in lower? without buying new shocks right now, I have cut the bump stop in half and i have reg tein springs, maybe switch the ones from the from to the back? But then it would look like a hot rod right cause the weight of the motor would make emm sit even lower then they did in the back right?
oh yeah if anyone lives in central florida, this dude that I bought the VC off of said his best friend does emm DIRT CHEAP!!!, dude lives in daytona and he said on the weekends he will spray coat them for like 10-20 bucks!!! pretty cheap!!!
