Transmission & Drivetrain Gearboxes, Differentials, Clutches
How to tell what type of diff bearing for JDM GSR tranny (YSK-1) ???
Old Nov 15, 2009 | 01:21 AM
vanny_david's Avatar
Default How to tell what type of diff bearing for JDM GSR tranny (YSK-1) ???
I bought a JDM GSR Tranny which has no label on it, the only stamp is "YSK-1" on it
and it grinds in 3rd after 4000rpm
I am going to rebuild the internal with brand new seals, bearing, and synchros..
The thing is: How will I know the differential bearing whether it is ball bearing or tappered bearing?
A direct method is to open up the case and see, but it is currently on my daily driver so the worst thing is to order all the parts and rebuild over the weekend.
Any idea what I can do?
Thanks,
Old Nov 15, 2009 | 09:59 AM
Honda Bull's Avatar
Default Re: How to tell what type of diff bearing for JDM GSR tranny (YSK-1) ???
Depending on the year, it could be either. Pre-96 they are all tapered bearings. So if you don't know the year of the trans, you're kinda beat until you open it up.
Chances are though that the diff bearings are just fine, and you'll need a special tool to measure the preload on the tapered bearings, so you may want to just skip on the diff bearings unless there is a serious issue with them.
USDM-EK4*
15
May 5, 2009 12:36 PM
mgags7
Sep 28, 2005 06:31 AM
LsTurbo91
Jul 16, 2002 08:00 PM
